Sponsored by: Innova
keyless entry install help
Old May 10, 2006 | 04:17 PM
fordgallor's Avatar
fordgallor
ibought an aftermarket keyless entry for my 1997 f-350 crew cab, it looked simple but i am having trouble figuring out what wire to hook into for the door lock. i only want the drivers front door to unlock when i push the button. anybody know where i need to lock. i have power window and locks!! thanks
Old May 10, 2006 | 11:22 PM
IPACA9's Avatar
IPACA9
You are going to have to install a relay on your drivers door motor wire to have drivers door priority unlocking.
Connect your lock and unlock wires as normal. Your keyless SHOULD have a priority unlock output. Most have this these days.
In your drivers door boot harness you will find a Red with Orange Stripe wire. You will have to cut this in half. Connect the wire going to your door to PIN 30. Connect the wire going to the body to PIN 87a. Connect PINS 87 and 86 to 12 volts constant. Connect pin 85 to the drivers priority unlock on your keyless entry.
presidentsdad
40
Sep 29, 2023 03:51 PM
jeezjamie
1997 - 2003 F150
Jun 26, 2012 07:00 AM
askbruce
Mar 16, 2012 01:12 AM
bass-n-fire
Oct 2, 2008 07:29 PM
Thudpucker
1997 - 2003 F150
Jul 17, 2007 09:31 AM
