Sponsored by: Real Truck
code read problem
Old May 9, 2006 | 08:46 PM
sturman3's Avatar
sturman3
code read problem
1999 F-350, 5.4 engine, auto, I plug in a brand new code reader under dash and get no reading , no light up, no nuttin' .. Tried the same reader in '03 F-150, 5.4 , auto.etc.etc.and it works fine Any ideas as to why no power to 16 pin obdII connector (checked all the fuses i could find)
Old May 9, 2006 | 09:02 PM
FortyFords's Avatar
FortyFords
Double chk fuse#3 it pwr's the dlc plug and also the cigar lighter.
Rich
Old May 9, 2006 | 09:05 PM
captchas's Avatar
captchas
Guest
all the fuses?
under the dash and hood .only time i had that problem was a loose of power .a blown fuse. bad wire.
recheck fuses under dash 15,19,30.under hood 5 and 7 . if you need a owners manual go into motorcraft.com and under owners guides down load your year ' newest edition.number 4- pages 145 on to end of chapter for fuse locations
Old May 9, 2006 | 10:26 PM
99f350sd's Avatar
99f350sd
Check for a bent pin on the DLC. Also connector 1049. If you have 12v at the cig lighter then its making it that far.
Pins 4 and 5 are grounds make sure they are good.
Dick
Old May 9, 2006 | 10:31 PM
whalerron's Avatar
whalerron
Does that truck use the CAN codes? My 2005 Superduty uses CAN codes and my OBDII reader would not work with it until I upgraded the software in the reader.
Old May 9, 2006 | 10:47 PM
FortyFords's Avatar
FortyFords
CAN ,came out in late 03 early 04.in our trucks
OBDII all the way up to that
Rich
