Help finding Ball Joint replacement info
Old May 9, 2006 | 11:02 AM
cooper's Avatar
cooper
Can someone help me find the info on Ball joint replacement for a 00 Excursion 4x4? Thanks.
Old May 9, 2006 | 12:01 PM
jschira's Avatar
jschira
Upper is Moog Part #K80026
http://www.rockauto.com/ref/Moog/Det...K80026_TOP.jpg
or Motorcraft Part # MCS1044273
Lower is Moog Part # K8607T
http://www.rockauto.com/ref/Moog/Det...K8607T_TOP.jpg
Or Motorcraft Part # MCS104149
Old May 9, 2006 | 02:08 PM
cooper's Avatar
cooper
Thanks for that.
I didn't have any wobbling or vibration issues until I replaced my tie rods. The drivers inner was frozen solid so I guess it was holding everything in place. Once I removed it, now everytime I brake it feels like the rotors warped or the front end is going to shake off. I went to replace my rotors and noticed I could push in and out on the bottom of the wheel. When I looked underneath I could see the ball joint giving way. My local mechanic gave me a quote of $830 for all four which seems to be inline with others on the forum. I think I would rather spend the labor money on new hubs and bearings though. Has anyone written up a procedure for replacing them on the F250 and Excursions? If so I would be most interested in finding that as well.
Thanks
Old May 9, 2006 | 02:24 PM
Racerguy's Avatar
Racerguy
https://www.ford-trucks.com/forums/s...d.php?t=354091
Old May 9, 2006 | 02:25 PM
jschira's Avatar
jschira
All 4 ball joints should be <$200, so I hope that includes labor.
Old May 9, 2006 | 02:28 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
4C3Z 3049-DA FORD LOWER BALL JOINT
Old May 9, 2006 | 08:10 PM
Forest's Avatar
Forest
Racerguy's instructions are good. I used them just this past week to replace all 4 of my ball joints. Most of my difficulty was in getting the axle out of the housing. Other than that, the instructions are great. You will need good mechanical experience to be able to do this yourself. The shop that quoted $830 is probably being reasonable. It is not a quick job.
Old May 15, 2006 | 06:56 PM
cooper's Avatar
cooper
Thanks Racerguy and all others, my PC gave me some fits the last few days I wasn't able to express my appreciation.
After reviewing the procedure though I feel I could get the equipment off but getting them pressed in and the axle pressed back on seems like a difficult task without those drivers.. Anyone have ideas on creating those?
Old May 15, 2006 | 07:14 PM
Kruse's Avatar
Kruse
Some places, like Autozone, lets you rent the tools for "free". Or you could buy a cheap ball joint press from places like Harbor Freight. I don't recommend the cheap press for a professional tech, but will work okay for a do-it-yourselfer.
Old May 29, 2006 | 11:56 AM
NewXer's Avatar
NewXer
I got the Ball joint & Tie rod press kit from Autozone. It cost me $120 for a deposit, kept it for 2 weeks, and they gave me the $$ back.
Old May 29, 2006 | 08:41 PM
cooper's Avatar
cooper
I decided against the DIY repair as I didn't have the drivers for removal, etc. The total cost was $1k. a bit steeper than the $830 quote, but also included turning my rotors. Anyway I wasn't happy but I didnt have to make the time to do it myself... I looked at the passenger wheel well yesterday and noticed fluid all around my well. I looked behind the wheel and it seems the axle is leaking. I bet they didnt change out the seal like they said either. I take it back in tomorrow for them to look it back over.
Hope everyone had a great memorial day.
BTW. All my wheel wobbling is gone. It seems like it wants to wonder though. I know my other components are up to dat as I replaced those before the joints.. Could be Abnormal tire wear from the other issues though.
