multifunction switch
Old May 9, 2006 | 10:59 AM
ilbigmike's Avatar
ilbigmike
Question multifunction switch
How much of pain is it to change? I have a 97 sport....my w/w,and turn signals are cutting out intermittantly and I get a buzzing noise once in awhile....any help will be appreciated, thanks! mike
Old May 9, 2006 | 12:48 PM
K2JJB's Avatar
K2JJB
easy to do, after market from local parts store was cheaper... took me about 45 minutes, but a lot of that was due to the cold and the dark when I did it (flashlight holding adds time to these things). See the following thread for more details:
https://www.ford-trucks.com/forums/s....php?p=3211791
-John B
Old May 9, 2006 | 01:02 PM
ilbigmike's Avatar
ilbigmike
thanks for the info and the links...im glad I do not have to remove steering wheel or the air bag....mike
Old May 9, 2006 | 03:22 PM
lotic's Avatar
lotic
I am not very mechanically inclined but I just changed my Multifunction Switch yesterday and it was one of the simpliest things I have ever done.
I went to the Ford Dealer and was charged $60 for a new one. I went home and took of the plastic covers that go over the steering column and removed the tilt wheel lever and the multifunction switch was right there. Unscrewed the 2 screws using a #20 star bit and unplugged the electrical connectors in the switch and put in the new switch in the exact reverse order of the way I took apart.
Took me a total of 20 minutes and I have never took apart the plastic covers around my steering column.
Veryyyyy easy to do.
Old May 14, 2006 | 08:25 AM
wz2wj1's Avatar
wz2wj1
I have a 96 and was having the same problems. Before you change the MFS take a look at the relays. Switch the relays around to see if the problem goes away or changes to something else. That was the problem on mine they were only 12.00. You can check the MFS with an ohms meter once it is out, the specs are in the haynes manual. It is a simple job to remove it & check it.
Old May 17, 2006 | 10:21 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
YL5Z13K359BAA FTE $38.53 in stock
Ed
smokersteve
Jun 6, 2012 12:35 PM
NtShade
Mar 3, 2012 01:26 AM
saggys
Modular V10 (6.8l)
Nov 4, 2010 12:09 PM
rooster41
New Member Introductions
Aug 26, 2009 03:01 PM
ScottInTexas
Jun 12, 2007 12:26 PM
