Suspension part
Old May 23, 2002 | 05:33 PM
AaronW's Avatar
AaronW
Suspension part
I need a front passenger lower shock bracket for my 69 F250 2wd. Salvage yards wont sell it and don't want to go to the trouble of pulling a radius arm. I know Johns F100 sells them new, but I called and it will take them atleast a week to get one in stock. Anyone have any suggestions?
Aaron
Old May 23, 2002 | 10:39 PM
mlf72f250's Avatar
mlf72f250
Suspension part
I always first check the sponsor's site, but didn't find it there.
Not seeing it there, i checked www.f100.com and found this:
https://www.f100.com/6772Shop/cat59.htm
Looks like they want $17.50 for it.
I need the same thing for mine, but haven't had the time to do it right. In the mean time i'm using a "HELP" universal lower shock kit ($5 at Kragen's). Unfortunately, I had to remove the shock's lower bushing to make it work.
Old May 24, 2002 | 12:29 AM
royf250's Avatar
royf250
Suspension part
If the old one is bad I think you'll have to wait for a new one. Junk yard brackets are hard to take off. It's going to be bad enough to have to take the old one off your own truck. When you do get the new one you're going to have to grind the two rivets off and pound out the rivets. I use 1/2" course thread, 1 1/2 length grade 5 bolts with nuts and lock washers. Seems to work fine. good luck
Old May 24, 2002 | 07:50 AM
AaronW's Avatar
AaronW
Suspension part
Well, I got the part. I ground the rivet heads off, just haven't had the patience to knock the rivets out. You sure its 1/2" and not 7/16" thread?
Aaron
Old May 24, 2002 | 07:55 AM
William's Avatar
William
Suspension part
Aaron, when you get the rivet out take it and the new bracket down to the local parts store and buy the correct size grade five bolt. I'd also use self locking nuts.
William in Atlanta
Old May 26, 2002 | 10:56 AM
jds1971's Avatar
jds1971
Suspension part
Old May 26, 2002 | 12:42 PM
royf250's Avatar
royf250
Suspension part
It's been a while, I agree to take the part to the local hardward store. It will take a 50/50 mixture of patience and braun to get the rest of the rivets out. I took 1/4 drill bit and drilled 1/4 inch into the rivets. I used an "expendable" large phillips screwdriver and pounded out each rivet.
Perry55
18
Feb 4, 2016 07:47 AM
BrodyUSMC
6.7L Power Stroke Diesel
Jul 21, 2015 07:35 PM
'78f350
Jun 16, 2014 06:44 PM
1978fordf250
Jun 15, 2013 11:38 AM
Boss50
Appearance & Dress-Up
Mar 22, 2006 11:02 PM
