headers
Old May 8, 2006 | 06:13 PM
mrobertm31's Avatar
mrobertm31
headers
just got a "new" 96 f150 eddie bauer. im trying to find a set of headers for it, but am coming to realize the 4.9L6 Y is not too common. can anyone tell me where i can find a set, or is this something that is going to have to be completely custom fabricated. any help would be greatly appreciated
Old May 8, 2006 | 06:27 PM
MustangGT221's Avatar
MustangGT221
Welcome to FTE!!
I say don't even bother - the factory manifolds have pleanty of airflow for that engine and are not very restrictive. You won't gain much if anything from a header swap like you would on a typical V-8 w/ crappy manifolds.
Also, don't forget we have an exhaust systems forum.
https://www.ford-trucks.com/forums/s...d.php?t=148601
Old May 8, 2006 | 06:31 PM
andym's Avatar
andym
Yeah, no one makes headers for the 300. The intake and head flows so poorly that the stock exhaust is more than adequate.
Most of the guys with carb'd 300s swap EFI manifolds on because they flow good.
Old May 8, 2006 | 06:35 PM
mrobertm31's Avatar
mrobertm31
its got efi, and i just installed a k&n cold air intake with an airaid throttle body spacer to help it breathe a little better. im just trying to open up the exhaust side more. the plan is to put a full custom exhaust, cut out the cat, n either do a short pipe side exit, or duals out the back. next question, for performance n sound, got any recommendations? ive never heard any 300 with a good exhaust so i have so reference to go off of
Old May 8, 2006 | 08:46 PM
MustangGT221
Kinda wasting your time..if you want power throw a V-8 in it it's easy enough...
Throw a cat back on it and call it a day. I ran a gibson dual sport kit on my previous truck (95 F-150 300) and it sounded pretty good. It's hard to find a good exhaust for those that don't make them sound like a tractor engine. It's the only kit I have heard that sounds good but my experience is limited with that.
Your typcial glasspacks or the like don't really sound good.
Old May 8, 2006 | 08:47 PM
radramrod2's Avatar
radramrod2
The only good sounding 4.9L exhaust I've ever heard was the one that it left the factory with.
Old May 9, 2006 | 10:00 PM
trlckynlck's Avatar
trlckynlck
i have a 92 300 and the best thing u can do to it is take the cat's off. also hooker does manek headers for it you can find them by calling summit racing. there about $360 and there the only ones i could find and ive been looking for a long time. where did u find the cold air intake and how's the spacer working out for ya???
Old May 9, 2006 | 10:07 PM
mrobertm31's Avatar
mrobertm31
auto zone actually carries the k&N cold air kit, just make sure you specify whether you have mass air or not. that n the spacer got me a tiny bit of low end n about 2 mpg highway. i think itsworth it. spacer was air raid, got it off of autotrucktoys.com. intake was about 150 n the spacer was around 90
Old May 10, 2006 | 08:55 AM
powerfordf1504x4's Avatar
powerfordf1504x4
cliffordperformance.com
Expensive but they have some 300 headers and other performance parts
Old May 10, 2006 | 08:58 AM
powerfordf1504x4
My friend owns a 300 81 ford and it sound goods and has nothing but 2 inch pipe and tips and it sound like a v eight down low but it has it's own disstive sound. Don't dis the 4.9
Old May 10, 2006 | 09:03 AM
81fordf-250's Avatar
81fordf-250
Yea
I am the owner of the 81 and It toke a lot of work to get the exhaust to sound the way I wanted it to. It has a good rumble down low and it will cackle when you rack the pipes but it isn't a v8 sound. I did notice a slight power loss when I put extra pipe on over the straigh pipe with a glass pack that it use to have. It is because of the small pipe I used to Y the exhaust under the bumper. Tips make the engine sound better but it never will sound like a v8. the tips give it a deeper rumble down low. They are a very good all around engine. Not a power house but will get the job done and last a long time. The 300 from the factory in this year had factory split manifolds so I can see how the flow wouldn't be a problem.
Old May 12, 2006 | 10:25 PM
trlckynlck's Avatar
trlckynlck
so 81fordf-250 do you have glasspacks or just stright pipes all the way back?
kopfenjager
Feb 27, 2005 07:34 PM
80 dump
Exhaust Systems
Jan 19, 2004 09:32 AM
nitro520
Mar 9, 2003 12:37 PM
ChrisAllen1090
1978 - 1996 Big Bronco
Sep 23, 2002 12:51 PM
