tune?
Old May 10, 2006 | 09:15 AM
f150 Man's Avatar
f150 Man
Originally Posted by ROUSH_Chris
F-150,
Roush reprograms the pcm for you, if you purchase our kit there is a prelabeled FedEx box in which you will mail the processor to us and we will flash it for you. No programmer or chip is needed.
what do u mean flash it?
Old May 10, 2006 | 09:17 AM
f150 Man's Avatar
f150 Man
sorry
sorry guys with not be to understanding with superchargers, im more of a turbo man, but i really didnt want to fool with those on my truck, i apprceate ur help
Old May 10, 2006 | 09:24 AM
Lone_Star's Avatar
Lone_Star
The driveshaft loop is basically a loop that goes around the driveshaft to protect the driveshaft from falling out. That way if you have failure you wont catapult the vehicle. Balancing the driveshaft will make sure the driveshaft does not vibrate at higher speeds. The 4x2 are notorious for having a week driveshaft from what I understand.
The flash, puts all the required programming into your pcm so that the computer will adjust for the supercharger. That way your vehicles parameters will be adjusted for Air/Fuel Ratios, shift points, etc, etc.
No worries, if you have any more questions just let me know. Thats what I am here for.
Old May 10, 2006 | 04:35 PM
frederic's Avatar
frederic
The modern day car computers (ECM, ECU, EEC's) contain flash chips, whereas instead of attaching a chip/dongle to the back of the computer, or replacing the memory chip (eeprom), you can "flash" the new code/data into the computer using a cable and a laptop, replacing the existing, factory set code/data.
Personally, I wouldn't send anyone your factory orginal EEC. Instead, I'd buy the same EEC from an auto parts store, rockauto.com, or on ebay (usually the cheapest), then send THAT one, this way should you ever decide to remove and sell the supercharger kit, you can simply remove it, plop the original EEC back into your truck, and turn the key for happy driving.
Some companies offer the option to retain the factory program and install a switch that allows you to select between factory settings, and the new supercharger settings. Not sure if Rousche or Trilogy offer that but if they do, that's another option of course.
Me, I'd still send "whomever" a spare EEC just to be safe.
And if you're really worried about driveshaft twistage, upgrade to an F350 driveshaft, and spend the time to figure out the custom u-joints. You won't break it.
Old May 10, 2006 | 09:28 PM
73mach1's Avatar
73mach1
i paid $4395 for my roush from the ford dealer so u can get them for less. got a tune from miketroyer for $600
Old May 10, 2006 | 10:37 PM
f150 Man's Avatar
f150 Man
just curious, but what kind of times have u ran with it, i just dont wqant to be disappointed, and what else do u have done.
Old May 11, 2006 | 07:00 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Originally Posted by BigF350
There are a number of programs you can use - the only one that I am aware that is completely customisable is SCT software.
Supercharger "kits" will include a tune program. Some will use existing tuners/chips (like I believe Trilogy uses the SCT), others will have thier own chip (Kenne Bell for example).
I thought I would add to this - all of the programmers are capable of doing this - you just need to give them your settings, and they will write a program for you, however the SCT is the most adjustable by someone that has the "Pro-racer" package.
i have 4x2, what do u mean by loop or balanced?
A loop around the driveshaft - this prevents the driveshaft spearing something it shouldn't, if you happen to be running cut slicks, and well.... the driveshaft doesn't appreciate what you are doing to it
Balancing a driveshaft essentially just makes the weight on the shaft on the more even to reduce vibration - and prevent the above happening.
A 2 piece shaft (ex F350 - like frederic said) could always be an investment.
thank u, i think ur the only one that has answered my ques.
No worries - we are here to help
Old May 11, 2006 | 08:07 AM
Lone_Star's Avatar
Lone_Star
73mach1,
Thats a great deal! Is that for an intercooled kit? Please let us know what kind of numbers you have put down with your kit. Thanks for sharing.
Old May 11, 2006 | 09:19 AM
Blurry94's Avatar
Blurry94
...A loop around the driveshaft - this prevents the driveshaft spearing something it shouldn't, if you happen to be running cut slicks, and well.... the driveshaft doesn't appreciate what you are doing to it ...
I couldn't agree more...a loop is cheap insurance if I do say so, and some track officials wont let you run if you have slicks and no loop.
Old May 11, 2006 | 09:38 AM
73mach1's Avatar
73mach1
Originally Posted by Lone_Star
73mach1,
its the non intercooled got it before the intercooled ones where out 338hp and 377tq 15.1 1/4 mi 04 4x4
http://media.putfile.com/smoken-f-150
Old May 11, 2006 | 04:50 PM
f150 Man's Avatar
f150 Man
very nice, i wonder what it could do with the intercooler, but 15.1, very nice sounds bad ***
did u do anything to change the sound of the supercharger.
Old May 11, 2006 | 11:42 PM
73mach1's Avatar
73mach1
thanks just magnaflow siso <a href="http://img100.imageshack.us/my.php?image=p31400045hz.jpg" target="_blank"><img src="http://img100.imageshack.us/img100/1778/p31400045hz.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a>
TheBludgeon
13
May 24, 2013 02:14 PM
zmock8
Dec 2, 2009 09:08 PM
jleal_21
Mar 4, 2009 05:07 PM
SVTRanger
Michigan Chapter
Feb 27, 2004 02:07 PM
ehagerty
13
Sep 10, 2003 09:39 PM
