ethanol
Old May 8, 2006 | 10:47 AM
Snowking's Avatar
Snowking
ethanol
Does anyone know what/ can we change to make our trucks run well on Ethanol? I have been considering making a still, but whenever they talk about converting trucks it's only for the newwer ones.
Old May 8, 2006 | 12:16 PM
Bear 45/70's Avatar
Bear 45/70
Nothing, if you are talking E85 or what they are producing now. If you mean straight ethonal, you need a bunch bigger jets and metering passages and to crank the timing up about double as it takes alot of alcohol and it burns real slow and cool compared to gas.
Old May 9, 2006 | 03:18 PM
biz4two's Avatar
biz4two
Arrow
Agree with Bear. If you are talking about E10 or E85, then the FE should be good to go...and no special modifications needed.
biz
_______________________________
1976 F150 LWB 390FE NP435 NP205 4x4 3.50s
Old May 9, 2006 | 10:26 PM
rusty70f100's Avatar
rusty70f100
Agreed.
You probably could advance the timing if you're going to be using E85, it is 105 octane after all. Also, it might like a bit richer jets.
The E10, just put that in the tank and go.
Old May 9, 2006 | 11:36 PM
Torque1st's Avatar
Torque1st
Posting Legend
For E85 up your compression to 12:1, get new larger stainless fuel lines, and PTFE lined rubber lines. Increase your fuel pump capacity 25%. Get rid of the carb and go to EFI to avoid aluminum carb corrosion problems. The carb can be modified with 27% larger jets but corrosion problems will persist especially with homemade E85 which is usually heavily laced with water.
See this link for more information:
http://www.answers.com/topic/e85
If you want alcohol you can get it free here:
http://www.theregister.co.uk/2006/04/06/alcohol_cloud/
