Sponsored by: Real Truck
A little TOO much fun !
Old May 8, 2006 | 12:28 AM
devildog_0431's Avatar
devildog_0431
Talking A little TOO much fun !
Went muddin today on my own and got buried in some fresh dirt about 2 feet deep some people covered a swamp w/....got high centered and could only rock it 4 inches back and forth. A GEO Tracker came along and I'm sad to say he pulled me out, LOL ! He only gave me the tug I needed to get that Transfer Case Pan over the pile of dirt that was hangin me up. So later on we decided to beat his Tracker up so he got it as stuck as he could by jumpin a ditch catchin some air straight into the whole I was in so I could pull him out and get even, haha. Pulled a big Toyota Pick-up out of the mud a couple times after he said he could never get stuck cuz he had lockers, yea right. I crawled through the mud he got stuck in and slowly creeped him out the hole to disgrace him. Then challenged him to a few laps around the home-made dirt track and sad to say on the final turn my tire broke the bead and flew off and he won OH I'M RUINED ! I didn't have a spare so I stole a buddies spare for a bit till I got my tire re-mounted an hour later and she's back on there now. QUITE A FUN SUNDAY EVENING.
Old May 8, 2006 | 11:15 PM
etcetera's Avatar
etcetera
I didn't know Toyota made a "big" pickup.
Sounds like fun, mud season is over most likely around here.
Eric
Old May 9, 2006 | 01:47 AM
MountainHound's Avatar
MountainHound
Sounds like a blast!
I used to have a Tracker-everybody laughed at it but they're suprisingly capable little offroaders.
And ditto on the "Big Toyota"?? Whatcha talkin' about??
Old May 9, 2006 | 09:27 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
"Big" is a relative term. He was probably comparing it to the Tracker
Old May 9, 2006 | 09:46 AM
rickgmi's Avatar
rickgmi
would that be the toyota tundra..think that is there full size one..looks kinda mid sized to me..
Old May 9, 2006 | 01:01 PM
devildog_0431
haha....an old late 80's toyota w/ the r22 4 banger in it. shoulda said a "small" truck w/ some big feet.
Old May 11, 2006 | 12:18 AM
the deno's Avatar
the deno
Talking
he probably meant big for a toyota not a big truck lol p.s. if i remember right theres a song that says i aint never had too much fun, besides it sounds like you had a lot of fun! the deno
Old May 11, 2006 | 06:27 AM
Aussie Pete's Avatar
Aussie Pete
Toyota are the devil. May they fail and die. Why would you buy jap when you can buy a real truck?
Old May 11, 2006 | 08:37 AM
Kerr's Avatar
Kerr
your weight probably killed you. I remember back in 99 when i had my SD. i would get stuck all the time mainly because the big bitch sank where other didnt. I remember twice at partys on the river i would go to leave and it would look like i had flat tires, but it was just a trick, the bottom of the tire had sank, up to the bottom of the wheel.
Old May 11, 2006 | 03:49 PM
devildog_0431
My trucks a heavy bitch indeed. The wieght is always a problem when I'm stuck, nobody can just pull me out, they have to tug be once or twice then I can just drive out. I was rockin it back and forth for like 10 minutes gaining ground but then the ruts just got too deep in that soft construction mud, I also noticed some rock I was caught on underneath afterwards. I went across it in 2wd at first cuz the top was dry, got hung up and put her in 4x4 and it was too late, already sank like a tank. AFter i got pulled out the tracker couldn't even make it a 1/5 the distance I did, haha....I made sure she was in 4 low and made it the whole way across...momentum helps.
Old May 11, 2006 | 06:54 PM
El Gato's Avatar
El Gato
That is so humiliating and funny!!! At least you had the ***** to admit your experience. A true Marine!
Old May 11, 2006 | 07:03 PM
krewat's Avatar
krewat
Not to be the newbie pain in the butt moderator, but this is getting a little too "saucy" ... if you know what I mean
Old May 11, 2006 | 07:12 PM
El Gato's Avatar
El Gato
Ten minutes after making my last post and reading yours Krewat I am still laughing.
Old May 11, 2006 | 08:32 PM
Dustin1690's Avatar
Dustin1690
Sounds like a lot of fun
Old May 15, 2006 | 06:21 PM
devildog_0431
Pulled out a Nissan Xterra yesterday, then I got stuck and it took him like 15 minutes of tuggin to pull me out, damn running boards were stuck, haha.
