6.0 Intercooler Install Writeup
Old Feb 17, 2008 | 01:10 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Jeremy, I have seen a lot of posts since this that claim the 6.0 IC is a waste of money, or not worth the minimal gains. Can you comment on this?
Old Feb 17, 2008 | 08:25 AM
alan hodges's Avatar
alan hodges
Thanks Jeremy! I did not know this was such an old thread. Thanks again for the info.
Old Feb 17, 2008 | 10:16 PM
jtharvey's Avatar
jtharvey
What I experienced, the gains were minimal. I saw no change in driving unloaded. The only difference I saw was when I was loaded or towing, and saw an EGT drop of about 100 degrees. Spoolup was the same as the stock IC.
Is it worth the money? Well, that's a little subjective. I think it depends on how much you can get one for, plus you have to consider the cost of the new IC boots that will be necessary for the install. Then there's the time to install it, and how much your time is worth is up to you. I got my IC for about $100, then another $50 or so for the boots, IIRC.
I had to do it over again knowing what I know now, I'll say I wouldndn't do it. Instead, I'd put that money toward saving for a good aftermarket IC. When I took out the 6.0 IC for the 7.3 Spearco I have now, I saw some noticeable improvements across the board. Unloaded & loaded EGT's were 150-200 degrees lower than the stock 6.0 IC (which means it's working even better when loaded when compared to the stock 7.3 IC) and turbo spool was quicker.
Old Feb 17, 2008 | 10:22 PM
bdrummonds's Avatar
bdrummonds
Mike I will give you a report in a week or so. I installed mine this weekend.
Old Mar 13, 2008 | 11:53 PM
jtharvey's Avatar
jtharvey
Some new information here about the actual install of a 6.0 IC: On some trucks, there may be clearance problems with the bottom of the IC and the lines running to the transmission cooler. The solution to this is either relocate the trans cooler to the front (first thing behind the grill) or to install a 6.0 transmission cooler (or similar). I did not have any clearance problems on my 2000 model year truck, but have found that some trucks, partucularly newer models, will have clearance issues.
Old Mar 14, 2008 | 08:39 AM
a-rod's Avatar
a-rod
And heres a picture of the lines that get in the way.
Encho
Mar 3, 2016 02:45 PM
scld1354
Dec 9, 2015 07:47 AM
Ford F834
Apr 7, 2012 06:32 AM
hairyboxnoogle
18
Mar 16, 2011 11:51 PM
helifixer
Feb 12, 2010 11:26 PM
