what is CPS?
Old May 7, 2006 | 11:27 PM
Zinfinity's Avatar
Zinfinity
what is CPS?
I have heard a lot about CPS failure and i am curious as to what it is? also is it an easy part to replace?
Old May 8, 2006 | 07:22 AM
F350_Hauler's Avatar
F350_Hauler
CPS Camshaft position sensor. Tells the computer where the crankshaft and camshaft are in their revolution so the computer knows when to fire the injectors and also helps it to interpret other data that it receives from other sensors. It is a black plastic piece that fits into the front of the engine block up a little from the crankshaft pulley and towards the passenger side. It is noticeable from under the truck. It is held in place with a little metal fork that has one 10 mm bolt holding it in. It has a wire connector clipped onto it. First remove the wire connector and then when you remove the bolt you can gently pry under the metal fork with a screwdriver, wiggling and prying. Takes two minutes to remove the old one and replace with a new one. It is a common cause of dead on the road powerstroke so alot of guys keep a spare one in the glovebox with a 10 mm wrench or socket.
Old May 8, 2006 | 11:35 AM
Riata_Ag's Avatar
Riata_Ag
Do you reccommend buying the CPS from a Ford or International dealership?
What is the approximate cost for a CPS?
Thanks,
Old May 8, 2006 | 11:44 AM
Ron McCafferty's Avatar
Ron McCafferty
usually International is cheaper. here in Lynchburg VA they were 20 dollars cheaper than Ford.
Old May 8, 2006 | 02:50 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Check on ebay. You can usually get them for around 45-50 bucks.
Old May 8, 2006 | 05:02 PM
F350_Hauler
Ditto. Some ebayers even sell two for around $80. If you're buying them ahead of time you can really save some moolah.
Old May 8, 2006 | 05:27 PM
powerstroked162's Avatar
powerstroked162
CPS gone bad huh? no good, I always knew there was somethin fishy about them child pertection services people. not lettin ya spank your kids and all. terrible situmatation
