Rear end ID
Old May 30, 2002 | 03:36 PM
MufassaMaxx's Avatar
MufassaMaxx
Rear end ID
I tried to find the ratio in my rear end but i think i did it wrong. Lifted one tire, marked it, and rotated tire 1 full turn. right?
the driveshaft rotated 1 and 3/4 times thus making it a 1.75? The mark started off parrallel to the ground( 3 o clock from the back of the truck), went around once and then ended up facing the ground straight down(6 o clock). What numbers can i give ya'll to know more, the axle code on the door id 08 i think.
Thanks
Nate
Old May 30, 2002 | 04:22 PM
unioncreek's Avatar
unioncreek
Rear end ID
I just went through this with my 72 F100. You have a 3.50 rear end. I thought I could just jack up one rear tire and turn it also. You need to turn both at the same time or have someone move it while you watch.
Bob
Old May 30, 2002 | 04:59 PM
MufassaMaxx
Rear end ID
thanks union, it's stumped me for the last 10 times i've tried that test.
Nate
Old May 30, 2002 | 09:25 PM
gtex's Avatar
gtex
Rear end ID
