Sponsored by: Real Truck
after market tach
Old May 7, 2006 | 09:00 PM
danny_g_76's Avatar
danny_g_76
after market tach
ehy i pulled the tach out of my 95 f-250. I wanted to put it in my 99 because it has sentimental value. I allready have a tach in the dash. I got all the wires hooked up and went to hook it up to the coil. I then relized that the truck doesnt have just one coil. I need to know were i can find te wire i need to splice to put in my tach. Thanks
Dan
Old May 11, 2006 | 03:25 PM
danny_g_76's Avatar
danny_g_76
can any one help me i dont want to leave the hole in the trim and i really want to get this thing hooked up before i get the truck on the road again.
Thanks Dan
Old May 11, 2006 | 03:54 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Wow. No one answered you? Weird...
What motor do you have?
It should be possible, you might need an adapter though...
Old May 11, 2006 | 09:50 PM
skip #7's Avatar
skip #7
Ford makes a tach driver ,Jegs sell it for like 65 bucks,I put a small tach in my 04 F150 STX as they don't come with a tach,it worked well.
Old May 12, 2006 | 07:51 AM
Rancha9's Avatar
Rancha9
My 2000 Ranger had 2 coils, and 2 plugs per cylinder. I had to find the factory wire that ran to the factory tach (That the truck didn't have, but the wire still worked). Worked great and was spot on. However, most tachs only have settings for 4, 6, and 8 cyl, so you may need an adapter to make it work correctly if it's a V-10. Best of luck to you....
Old May 14, 2006 | 01:31 AM
danny_g_76's Avatar
danny_g_76
how can i find out what wire controls the tach in the dash. I have a v-8 5.4L. It was in my 95 with a v-8.
Thanks Dan
Old May 14, 2006 | 07:33 AM
Rancha9's Avatar
Rancha9
I had to pick through my Haynes manual to find which one it was, then I had to hunt it down in the engine compartment. It was in a big bundle of wires on the firewall, but that was on a Ranger. If you can find the color that it's supposed to be, and can't find it in the engine compartment, you may have to go hunting behind the dash...
