Stearing colume
Old May 7, 2006 | 07:39 PM
Joe T.'s Avatar
Joe T.
Stearing colume
Our '55 project came with a early 70's GM stearing colume. Since it doesn't mount securly to the frame like the origional, is there bracketry or advice available for mounting it ? Thanks, Joe
Old May 8, 2006 | 12:04 AM
wmjoe1953's Avatar
wmjoe1953
Are you going stock, or modified? I don't particularly care for the look of some of the GM installs, they just don't seem to look like they fit. There are some floor mounts available in the aftermarket world, you could try them. Otherwise, you're going to probably end up fabricating your own bracket. If you fab one, make it bolt to the dash like stock, and maybe another part that bolts to the firewall.
Old May 8, 2006 | 05:10 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I made my own bracket by welding a muffler clamp to a piece of flat stock and bolting it to the floor.
Vern
Old May 8, 2006 | 07:42 AM
AXracer's Avatar
AXracer
Yes, you need a floor mount for the column. Measure the outside diameter then buy or fabricate a mount. Cheapest/simplest mount is 3 small L brackets from the hardware store. Bolt to the floor in a Y pattern around the column and use short metal screws to attach them to the column. Most expensive but most attractive when mounted on top of carpet is one of the swivel billet ones.
Old May 8, 2006 | 05:03 PM
Joe T.'s Avatar
Joe T.
Thanks guys !
Old May 8, 2006 | 05:55 PM
jniolon's Avatar
jniolon
old and in the way
later
john
Old May 8, 2006 | 10:46 PM
Joe T.'s Avatar
Joe T.
That will hold it snug !
Old May 9, 2006 | 06:26 AM
GreatNorthWoods
Originally Posted by jniolon
later
john
A picture is worth a 1000 words. That's just like mine...
Vern
Old May 9, 2006 | 05:10 PM
rhopper's Avatar
rhopper
That's better than what I came up with. I love simple and cheap.
