ford part number/script rad hoses and heater hoses
I am gettign ready to put a new water pump on my 54 with a 292. It was a factory v8 truck. It has flex hoses and napa heating hoses. they all work fine but i want to go back to factory or as close as possible. does anyone know where or what the factory stuff looks like? i think the rad hoses were ford script maybe with part numbers on the top and possibly bottom. also anyone know abuot the heater hoses? I would like to order the stuff this week so i can drive my truck. thanks
hoses
if you are looking for molded hoses to work with the upgraded motor go to the parts place and look at there picture book make sure to get measurements inlet outlet and the twists if any should find hoses that will work for you not fomoco but they will look better then flex hoses. may have to cut to fit but they will look stockhope this helps . julie
Concours Parts sells radiator hoses for the 272 and 292 V8 from '56 to '60. They may work for your truck depending on the radiator you have and where the upper and lower connections are located. If you have a stock type radiator, that will fit these hoses. The catalog does not say if they are marked like Ford originals.
www.concoursparts.com
Phone 800-722-0009
Phone 800-722-0009
