What does this sound like? Need Help again
Old May 7, 2006 | 06:51 PM
afrantom's Avatar
afrantom
It has done this three time in a day in a half. when the fuel starts getting low, roughly 1/8th of a tank or so. (I know I am nlot suppose to let it get that low, but sometimes on long trips it happens). The truck starts to jerk and wants to die. It actually did today. It is not getting any fuel. yet when I fill up, it only takes 26 gallons and that is all the way up the filler neck. (29 gallon tank). once full, then it runs again. but there is still at least 4-5 gallons in the tank. I am also getting horrible fuel mileage. where I usually get 17 on the hiway, now I am getting 10 -101/2 mpg. any help would be great before I talk to the dealer. or should I even worry about it?
Old May 7, 2006 | 08:17 PM
Maxium4x4's Avatar
Maxium4x4
Just an idea: You may have a cracked fuel pickup tube which would allow air in the system. Have it checked out.
Old May 7, 2006 | 08:25 PM
firesoutmatt's Avatar
firesoutmatt
What year truck ? I know my 01 had a fuel inlet mod that covered up the bypass port on the pick up tube inside the tank. Sounds like thats the problem your having. Diesel Manor has a kit you can buy that will take care of that problem. You have to remove the sending unit. I don't know if the 04/05's have the same set up as my 01 did. I havn't had time to do the harpoon mod yet on my 05.
Old May 7, 2006 | 08:26 PM
afrantom's Avatar
afrantom
Thanks Max... I will take it in tomorrow and mention this. It isn't tripping any codes, so I hope they look a little deeper than just the diagnostic tool.
Old May 7, 2006 | 08:32 PM
Maxium4x4's Avatar
Maxium4x4
No problem, you just have to start somewhere and from what you describe I would check the tank first to eliminate any question.
brokersteve
Jun 18, 2013 04:02 AM
dbeames
1997 - 2003 F150
Nov 8, 2011 09:56 PM
danlee
May 7, 2008 06:47 PM
elvia
18
Aug 19, 2007 08:49 PM
fisher1995
Jun 8, 2007 08:25 AM
