Vibration fix?!
Old May 7, 2006 | 11:04 AM
Wolfdog's Avatar
Wolfdog
Vibration fix?!
Hi,
Until two weeks ago I was just reading and feeling sorry for F-150 2004 owners who wrote about the vibration problems. Then it happened to me as well..
Two weeks ago an extreme vibration at any speed comes and goes- suddenly. I tried different speeds and moderate/aggressive driving -- no pattern found.
I lifted up the back of my truck, took off the wheels and rotors and found following in summary:
- left wheel was always warmer (not hot) than the right one after driving
- right axle seal is either wrongly installed by the Swiss car mech, but it leaked oil
- brake pads needed changing
- left parking brake shoes looked a bit bad -- not smoothly worn out (small holes
Repair (at least after 150miles it has worked):
- turned the rotors inside out!
- put the thing together
No vibration anymore. Sounds unbelievable...but it seemed to work.
So I think the left parking brake has been touching the inner rotor surface during driving randomly.
Just wanted to let you know.
Old May 7, 2006 | 04:20 PM
CMOS's Avatar
CMOS
Thanks for the update. There does not seem to be a single cause of the vibrations on these trucks. BUt, it's nice to know at least we have a "list" to go down for those who have to troublshoot. (My 04 FX4 is, luckily, smooth as glass.)
CMOS
Old May 7, 2006 | 04:35 PM
WhëëlMå1's Avatar
WhëëlMå1
Glad to see you fixed the problem. It sounds like the well known parking brake issue. It sticks randomly, and you cant pinpoint the extreme vibration. If you do a search, I wrote the entire work order in a post, that was used to fix mine.
