Change engine 6.9L bolt up?
Old May 13, 2006 | 07:25 AM
82F100SWB's Avatar
82F100SWB
That bellhousing will definatley work, the flywheel? Highly unlikley
Old May 13, 2006 | 08:44 AM
bluthunder's Avatar
bluthunder
[QUOTE=Dave Sponaugle]If your 6.9 does not have bottom end torque, something is wrong.
I broke more than one U joint with my 6.9 bottom end torque.
I also pulled over 20,000 gross weight here in the WV mountains with my 6.9.[pulling that much weight, how did you stop the dang thing?/QUOTE]
Old May 13, 2006 | 09:31 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Brakes and gearing down.
Since I am a retired over the road truck driver, I am very used to the extra stopping distance required when loaded heavy. I also take no shortcuts when working on the brake system or for that matter any of the rest of the truck, if anything is worn or questionable, replace it with new. Trailer brakes are just as important as the tow vehicle brakes are. They get the same attention that the truck brakes do.
For several years I had the stock vacuum brake booster and it was OK. Now I am running a hydraboost unit off a 97 Superduty (F450) since I have added a turbo to the mix.
Old May 16, 2006 | 09:03 AM
81fordf-250's Avatar
81fordf-250
i have a 7.3
my dad has an extra 89 7.3 none turbo. We also will have a 6.9 that need rebuilt we are puting in a 7.3 in our truck and are getting 2 motors in the deal. plus an automatic overdrive trans will 3000 miles on it. Any body interested? what kind of price could we sell the trans for?
Old May 16, 2006 | 11:18 AM
81fordf-250
our 6.9
I have tried to power brake my dads 6.9 in first gear and it died. My 300 will power brake in secound. The timing is a little advanced on my dads truck to get the top end power up. It has precombustion cylinder heads. Did they all have this type of head.
mitchgordon96
Jul 30, 2014 05:35 PM
LSO1123
16
Aug 26, 2011 04:47 AM
hugger94
Sep 1, 2008 09:28 PM
ned1974
Aug 22, 2007 09:26 PM
HT32BSX115
May 13, 2007 03:31 PM
