transmission compatability
Old Aug 25, 2011 | 03:05 PM
LSO1123's Avatar
LSO1123
Will a 4 speed manual trans out of an 87 f250 6.9 bolt up to a 94 7.3 idi?
Old Aug 25, 2011 | 03:09 PM
snaponprofile's Avatar
snaponprofile
Bell housings are the same, but why not a zf5?
Old Aug 25, 2011 | 03:10 PM
joe f350's Avatar
joe f350
hey probley cant find one in his price range or he likes the t19 better
Old Aug 25, 2011 | 04:30 PM
LSO1123's Avatar
LSO1123
You're dead on the money Joe! I have no prefrence for a T19 over a ZF5 but I'm wanting a complete donor truck to do the swap plus that way I'll have some other parts too if I need them some time or another. I'm having a hard time finding a truck with a ZF5 that is in my price range but I have found a 87 F250 with a good 6.9 that fits in my price range. I just wanted to make sure the T19 would work. I thought it would cause I saw a 94 IDI turbo once that had a 4 speed in it but I wanted to ask you guys anyway. I'm pretty sure I read that I will need a flywheel from a 93-94 turbo truck but what about the clutch and everything else, will they interchange?
Old Aug 25, 2011 | 05:09 PM
1994F2507.3L's Avatar
1994F2507.3L
you should be able to take everything from the 87 and move it over to the 94 id think..... the bell housing patterns should be the same but i don't think you can run the DMF from the ZF5 on the T19......
Old Aug 25, 2011 | 05:23 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
yup.you'll lower the resale value to almost free,and the fuel economy down the drain as well.but its possible.
cost of operation trumps initial cost.
of course if your just doing this for a yard/plow/fun off road play toy where fuel economy driving in OD wouldn't happen either way.then heck id even do that myself before i payed big bucks to have an E40D looked into,or a zf5 swap.
it sure would take a lot more than just a TPS out of range code to make me even think about all that work though even if i had the donor already lol.
Old Aug 25, 2011 | 05:36 PM
joe f350's Avatar
joe f350
u know i can get 20 mpg at 55 empty and arond 10 15 loaded. i dont really see that has a big drop. u may haved payed big bucks for a e4od but not ever budy share ur veiws on the e40d. im my mind its the best paper weight ford ever made
Old Aug 25, 2011 | 05:49 PM
FORDF250HDXLT
thats whats so cool about the forum Joe.everyone gets to express their opinions and experiences so others can make their own decisions.
nah.i payed less for my whole truck than the cost of a reman E40D 2 yrs ago Joe.
(of course it wasn't much compared to what it is today.)
Old Aug 25, 2011 | 06:12 PM
LSO1123's Avatar
LSO1123
I wouldn't give 10 cents for either of my e4od's! Just because of all the electrical crap that has to be working just right! It may just be a TPS problem but its a problem that I can't seem to get fixed.
Old Aug 25, 2011 | 06:18 PM
joe f350's Avatar
joe f350
Gear Ratio Calculator
u know i did some math with my 37s and 410 atn a t19 i turn 2048 rpm
know with a e40d 31s and 4 10s would turn 1735 at the same seed
i dont see a big diffrents
Old Aug 25, 2011 | 06:19 PM
FORDF250HDXLT
did you make sure the plug was clean? if there is corrosion at this plug,or the plug at the brain for this pin,this could explain that.
the tps plug is easy to clean,as you know.but what about at the brain? that just takes a 10 mm socket.pull the plug and clean these terminals.it could be such an easy fix.start with the little things first and work your way up.this is how i try to deal with things.
Old Aug 25, 2011 | 06:22 PM
FORDF250HDXLT
your comparing apples to oranges Joe.
compare the same trans with the same gears AND tires.then you'll see the difference.
if you swapped in the zf5 or E40D into your truck,still test at 55 mph like your doing now, and made no other changes..........oh yes.you'd see it and be smiling.
Old Aug 25, 2011 | 06:40 PM
joe f350's Avatar
joe f350
i know that but u keep saying i wonder how u get 20 mpg with my truck i just told u lol
Old Aug 25, 2011 | 06:54 PM
LSO1123's Avatar
LSO1123
250 are you talking about where the TPS plugs into the TCM? What about my TPS not being able to adjust to within range? I've put two new TPS in it and still no change.
Old Aug 25, 2011 | 10:42 PM
Dodge/Cummins's Avatar
Dodge/Cummins
Did somebody edit this post?!
I understood it the first time through!
