2003 Expedition paint problem...
Old May 6, 2006 | 02:27 PM
2005Mariner's Avatar
2005Mariner
Cool 2003 Expedition paint problem...
I am the original owner of a 2003 Expedition (build date 09/02), with the Medium Wedgewood Blue paint. I purchased it on May 23, 2003. I was getting ready to put a coat of wax on it, as it finally stopped raining here in SoCal. The "channels" that run the length of the truck on the roof, on the outside of the luggage rack rails, have paint that is "cracking and spitting apart" (not to the point of peeling yet) in the bottom of the channels. In additon, the area on the roof, just in front of the factory moonroof and just behind the front windshield, has an area where the paint looks "worn out" and "faded" (very obvious). It is about 10-12 inches in diameter. Has anyone else had this problem and what do you think the dealer is going to say? It is still just barely under the 3yr/36K warranty, as it only has 30,000 miles on it and always garaged. I have never noticed it before and it get's two coats of wax per year, hand-applied by myself. This vehicle is paid off and we plan on keeping it until it dies and do not want to have serious paint issues in a couple of years. I owned two Chevy Camaro's (1989 and 1991) when I was younger and the paint just about washed off of them. I have since seen the light and bought Mustang's. I sure do not want to go through that again. Any help would be greatly appreciated.
Old May 6, 2006 | 03:03 PM
AF Mezkin's Avatar
AF Mezkin
Still under warranty. I would take it back to the dealer and have it repaired under warranty, just incase the problem returns, gets worse, or happens at another area, it has already been documented.
We pay a whole lot of money for these vehicles, I for one used the warranty down to the last day. I even had the dealer repair my driver seat, at no cost to me, after the Expy was out of warranty (38K) because it had been reapired twice during warranty. (documentation)
Old May 7, 2006 | 06:19 PM
aagitch's Avatar
aagitch
If you have the basic warranty, your warranty ends 3 years after the manufacture date. In your case it would end 09/05. A really good dealer might try and cover it under warranty anyway.
Old May 7, 2006 | 07:13 PM
AF Mezkin's Avatar
AF Mezkin
Actually the warranty starts as soon as the vehicle is purchased for the first time, you have 3/36k from that point in time which ever come first. So, your warranty runs out May 23 '06 the lastest.
Old May 7, 2006 | 08:00 PM
aagitch's Avatar
aagitch
Oops, that's right sorry for the confusion. Mixed it up with something else
Old Oct 19, 2006 | 10:38 PM
Bry's Avatar
Bry
actually on the newer trucks and cars ford warranties the paint for five years unlimitied mileage or at least that is what my warranty book says
Old Oct 19, 2006 | 10:46 PM
bridge's Avatar
bridge
Sick 'n Tired
Welcome to the site. I think you are referring to the corrosion coverage. The below is from the Ford Website:
"Under the New Vehicle Limited Warranty, Corrosion Coverage begins at the warranty start date and covers body sheet metal panels against corrosion due to a defect in factory-supplied materials and workmanship. Corrosion coverage (which lasts for 5 years, regardless of miles driven, and features no-deductibles) only applies if the corrosion causes perforation (holes) in the body sheet metal panels.
If corrosion does not cause perforation (holes), and is not the result of usage and/or environmental conditions, paint damage is covered under the terms of the Bumper-to-Bumper Warranty (3 years/36,000 miles, whichever occurs first). "
Unfortunatly, It looks like paint issues are only covered 3/36 unless it's so bad the metal gets perfed. Figures.
I'd almost expect the original posters problems with blue paint. Blues and reds are more succeptable to oxidation and sun fade than other colors. It's a shame these cars don't get a few clearcoat coats.
Old Oct 19, 2006 | 11:26 PM
Bry's Avatar
Bry
ah i c well hmmm good and bad eh? LOL luckily i have no problems with my 03 eb...
Old Sep 14, 2009 | 12:16 PM
chiefjefe's Avatar
chiefjefe
I know this is an old post but I recently discovered the same problem on my 03. The paint is cracking on both roof channels the length of the of roof. Unfortunately, my warranty has expired. Has anyone experience this problem recently and does anyone know how much a repair like this would cost? If it's simple, I'll take care of it myself but I don't want to bite off more than I can chew.
Old Sep 14, 2009 | 12:35 PM
99Exp's Avatar
99Exp
Mine is doing the same thing. Seems like a lot of us have this problem. Mine is the Medium wedgewood blue also.
Old Sep 15, 2009 | 04:06 AM
broncoholic's Avatar
broncoholic
Aspen Green 03, roof channels cracking also. Looks to me there is a "putty" in there to seal it and the paint is cracking from the years of expansion and contraction of the putty. No leaks + no signs of rust = no worries in my book.
Old Sep 15, 2009 | 09:27 AM
chiefjefe's Avatar
chiefjefe
I have the 03 silver birch. I also don't have any leaks or rust but would like to prevent that from happening. I'll see if I can get a quote from the dealer.
Old Sep 16, 2009 | 12:33 PM
AF Mezkin's Avatar
AF Mezkin
My 03 Az. Beige has the same problem, mine are hair line cracks on the paint, no splitting yet. I concider it minor for now, but I might look into what type of sealant is used in the channel.
Old Sep 16, 2009 | 07:59 PM
ronjeremy6's Avatar
ronjeremy6
my 05 estate green has the cracking paint inside the rain channels. been like this for 2 years now. it stays in the garage while home so hopefully it will not pose a problem in the long term.
Old Jul 8, 2010 | 08:30 PM
zestar's Avatar
zestar
Lightbulb Paint Thickness Role In Factory Paint Defects
Paint durability data associated with the Ford Expedition and Lincoln Navigator is documented in the research publication:
MAKING IT RIGHT
Why your Car Payments are lasting longer than your
FACTORY PAINT JOB
There has also been an independent review done of this publication by
"ForeWord".
Automotive paint durability research publication documents vehicles released to dealer and consumer below automaker's minimum paint thickness specifications.
Refer to link for details.
Link: http://www.forewordreviews.com/reviews/making-it-right-why-your-car-payments-are-lasting-longer-than-your-factory-paint-job-basic-guide/
wmclark43
Appearance & Dress-Up
Jul 11, 2016 03:50 PM
ExTerrestrial
Oct 10, 2014 08:43 PM
93f250tn
1983 - 2012 Ranger & B-Series
17
Sep 14, 2011 03:30 AM
tbm3fan
19
Sep 19, 2009 05:27 PM
smitty240
Jul 24, 2004 08:12 PM
