General Automotive Discussion
cutting tires up?
Old May 6, 2006 | 01:32 PM
cjben's Avatar
cjben
cutting tires up?
what is a good way to cut tires into 4 pieces? like quartering them. I rented a dumpster to get rid of some of the stuff in my garage and around my house. they said they will take tires,but they have to be cut into 4 pieces. I have a hand saw that is for wood and a saws all with a metal cutting blade in it. will either one of these tools work?
Old May 6, 2006 | 01:39 PM
Neb86's Avatar
Neb86
I don't see why a saws-all wouldn't work. I've never had to cut up any tires though, so I don't have any better suggestions.
Good luck!
Old May 6, 2006 | 02:07 PM
bigdaddyII's Avatar
bigdaddyII
Use the saws-all and see if it really holds up to its name. I have never had to cut a tire before either but I can imagine that it will be a chore.
Old May 6, 2006 | 02:10 PM
john112deere's Avatar
john112deere
I've done it with a chain saw. I'd imagine the Sawzall should do pretty well, too, though probably a bit slower.
Old May 6, 2006 | 03:42 PM
donjamer's Avatar
donjamer
The saws-all works, but you need to have something to stop the bouncing. When cutting they tend to vibrate which takes away from the saws-all cutting.
The side walls are easy the problem is the Treads and the beads. When cutting the treads cut horizontal not vertical. This reduces the bounce.
The beads are easy if there is no rim. If it is on a rim you need to cut the rim to get them off otherwise it will take forever.
If you use the Saws-all get a big pack of blades.
Another thing to try is a grinder with a cutoff blade. I havn't tried this so I do not know if it is easier.
Old May 6, 2006 | 08:17 PM
JD717's Avatar
JD717
I would imagine it is easier. or just rent one of those cutoff saws with a concrete blade on it, those should cut it up easily.
the Sawzall is a sure bet, besides, its a good chance to see if it really sawz ALL if it doesnt, send it back for a refund saying it wont saw ALL.
Old May 6, 2006 | 09:26 PM
furball69's Avatar
furball69
I've tried to cut steel braided steam hoses with a hack saw and, while it can be done, it is a PITA. I can't imagine a sawzall on tires being much easier. Best bet, as mentioned already, a grinder with a cutoff wheel. I don't suppose you have a fire pit.
Old May 6, 2006 | 11:45 PM
whowey's Avatar
whowey
Sawzall and a 18TPI blade. I cut about 60 tires in half in a little over an hour for a school playground project.
Old May 7, 2006 | 06:43 AM
rebocardo's Avatar
rebocardo
As long as you do not have a off road tire (since the bead is literally 1/4" of spring steel) a sawzall works fine. I use either a 6" bi-metal or construction blade.
Old May 7, 2006 | 09:48 AM
jake00's Avatar
jake00
just send em out junk mail.
I've used a recip. saw in the past
Old May 8, 2006 | 01:15 PM
pitrow's Avatar
pitrow
use a oxy/acetalene torch
Old May 8, 2006 | 02:11 PM
GLR's Avatar
GLR
A torch sure does make a mess, and EPA people get upset..
Old May 8, 2006 | 08:03 PM
furball69's Avatar
furball69
I was going to be bad and suggest a ditch at 01:00, but I won't.
Old May 8, 2006 | 10:02 PM
preppypyro's Avatar
preppypyro
What about just throwing them with a stack of no good tires at a walmart tire center, or another garage?
Old May 11, 2006 | 04:53 PM
seventyseven250's Avatar
seventyseven250
I'm with preppy, find somewhere you can recycle those. Around here, it's five bucks a tire at the local dump, and they get recycled.
jniolon
Aug 13, 2013 06:44 PM
red66chevelle
Oct 20, 2007 07:18 AM
BigOle'Ford
Offroad & 4x4
Jun 25, 2007 04:39 PM
Skipped_link
Offroad & 4x4
19
Feb 4, 2006 12:09 AM
SkiDooHauler
Garage & Workshop
24
Sep 4, 2004 12:01 AM
