1978 - 1996 Big Bronco
Broken Key
Old May 6, 2006 | 11:29 AM
8a_bronco's Avatar
8a_bronco
Broken Key
Has anybody an idea of how to pull out the half of the key from the ignition switch without disasembling the steering column?
I can get the truck started but I don't know for how long.
Thanks.
Old May 6, 2006 | 12:21 PM
aurgathor's Avatar
aurgathor
There is a pin on the bottom of the ignition cylinder that is reachable in the ON position. You push that pin in, and pull the cylinder out.
I made some pictures when I replaced mine, but they all came out very crappy so I just deleted them, but you can search for 'replacement' threads -- you need to take out the old one and either install a new one, or take the old one to a locksmith so he can fish the broken key out.
Old May 6, 2006 | 02:46 PM
Encho's Avatar
Encho
The Southernmost Mod
I took my truck to a locksmith because he only charged me 3.50$ for the key extraction, taking down the column is a pain.
Old May 6, 2006 | 06:16 PM
Streetgang's Avatar
Streetgang
Turn the key to the "on" position and look up at the underside of the column where the key goes in. You will see a small hole there...its like 1mm in diameter. You need to stick a paper clip or something like that up in there while pulling outward on the key switch. Then just put a new key switch in......they are only like $25.00
Or at least with the switch out and in your hand it will not be so hard to get the busted part of the key out.
