Truck Stalling Out?
I had something strange happen to me earlier while in my truck and I was hoping someone may have some advice as to what my problem(s) may be.
First off, my truck is a 1990 full size EB with the 351W and 5.8 liter engine. I had been driving for an hour or so, off and on, as I ran some errands. I started to hear a strange noise coming from under the truck that I had never heard before. It seemed to be coming from the center portion of the truck, not the back end or engine. It sounded like a low-pitched whining, almost like hearing a bulldozer or something running from a few blocks away. More of a background noise. (Sounded like it may have even been coming from somewhere near the catalytic converters, not sure.)
Anyway, the truck ran fine but for the noise, so I decided to finish my errands. As I was leaving somewhere though, I started the truck and the noise was still there, so hit the gas while in park, revved the engine just for kicks, and the noise disappeared. Curious.
I was still thinking about it when the next thing happened. I was pulling out of a driveway which had a decent incline to it, perhaps 35-40 degrees. While I was waiting to pull into traffic, sitting on the incline, my engine stalled. First time it has happened since I owned the thing. (About 3 months. Same for the noise - First time.) Well, the truck would turn over fine, but it acted as though it was not getting any gas. (It has half a tank full, so that's not the problem). It started once or twice, but literally stalled within 2 seconds once more, still not getting any fuel.
I finally got some help and pushed the truck back up into the parking lot and on level ground... and of course the truck promptly started again on the first try. I drove it home, about 4 miles or so, with no problem at all and it ran like usual.
My problem is, I'm worried this may start happening more and I was wondering if anyone else has experienced this or may know what this is. I'm not even sure if the noise and the stalling are connected, but it seems suspicious since both happened today for the first time.
I just recently, (about 3 weeks ago), had a tune-up, oil change and replaced the fuel filter. Also, it has a brand new fuel tank. I suppose the new filter could be clogged, but my first thought was maybe my fuel pump is going out. I've never had any of the warning lights come on though, so I don't know.
Anyway, any thoughts or advice is greatly appreciated. I apologize for the long post, I can get a bit wordy. Also, before anyone even mentions it, no, I didn't pull the codes. I don't have the machine, am afraid to drive it to an Autozone for fear of getting stranded, and I can't seem to get the paper clip method to work for me for some reason.
Thanks again.
C.
If it is (or even if it is not) you need to pull the codes from the computer. It is very easy and can be done with no tools at all, but for a paper clip. Go to this site and read up on pulling codes, and post back what you get.
http://fordfuelinjection.com/?p=13
14 -- Two or more successive erratic Profile Ignition Pickup (PIP) pulses occurred, resulting in a possible engine miss or stall.
18 -- IDM circuit failure or SPOUT circuit grounded.
33 -- EGR valve opening not detected.
87 -- (KOEO) Fuel pump primary circuit failure. When the FP relay was activated by the EEC, voltage was not detected on the control circuit.
(CM) Voltage was not detected on Fuel Pump Monitor while the engine was running.
Admittedly, I'm not mechanically inclined at all so I have no clue really what any of those specifically mean. It's pretty clear though that it is the last one, the 87, that is causing my problem. Does this mean the whole fuel pump needs replacing? Any clarification on what all the codes mean in layman's terms would be greatly appreciated.
Again, thanks for the help already. You guys are great here.
C.
Code 18 indicates a loss of engine RPM (SPOUT) signal from the IDM/TFI module to the ECA. Make certain the SPOUT connector is fully seated in its receptacle. Further testing would require having the IDM/TFI module tested. (Most major parts stores will do this for free). This may be inter-related to the previous code as both deal with spark timing.
Code 33 is indicative of a problem with the movement of the EGR valve and the first check should be the vacuum line between the EGR valve and the EVR solenoid. Inspect for cracks and repair if necessary. If the vacuum line is intact, check the EGR valve for proper movement and clean to remove debris that may cause binding. If the EGR valve moves readily, apply vacuum and verify that the valve actualy holds when vacuum is applied. If not, replace the EGR valve. If it DOES hold under vacuum, replace the EVP sensor atop the EGR valve and re-administer the KOER test. Cleaning and inspection of the EGR valve requires either sucking on the vacuum barb and watching the pintle unseat and re-seat through the holes in the side of the valve or appliying vacuum with a pump and doing the same. Cleaning can be accomplished with throttle body cleaner carefully applied and the repeated movement of the pintle either with a vacuum supply or with a small screwdriver through one of the holes in the valve.
Code 87 indicates a failure in the primary fuel pump circuit. To troubleshoot, make certain the inertia switch has not been tripped. If not, then check for battery voltage at the LT.BLUE/ORANGE wire on the fuel pump relay (FPR). If there is battery voltage present (12VDC) check the wire itself back to pin 22 of the ECA (EEC-IV computer). The resistance through the wire should NOT EXCEED 5 ohms. Lack of voltage indicates a dead interia switch if the switch is engaged. If there IS voltage but the code still exists, replace the FPR.
There are more details to be given should any of these prove to be the issue. I have only touched briefly on the possible causes and how to check for them.
