I recently picked up some parts off a 1953 F-600 dump truck. One of the items was a flathead engine. I plan to put it in Frankie (the driver I am building). I don't want to use the four speed tranny mated to the flathead because of its very low gears. I have a good three speed I want to use instead. The problem is it won't bolt up because the bellhousing is specific to the four speed. Thanks, Henry!
So, I need a '53 bellhousing for a three speed. Anybody have one holding down the roof of their doghouse or using it as a planter for the Mrs.? This particular bellhousing was unique to '53. '52 and earlier is different. Not sure what, if any, bellhousings from a car might work. I don't have any books with car part numbers. Any flathead gurus care to give their two cents? Any help would be greatly appreciated!
You may have the perfect set up, if it's like the earlier bigger Ford trucks, to install a modern T-5 transmission in your truck. You will have better gears with OD. You need to retain the piece between the flywheel housing and the transmission, sometimes referred to as the "Dog House", or something like that.
You will also need to fabricate or buy an adapter plate to bolt to the new transmission to. Do a search of this site about the T-5. I know there is a member that did just this to his truck unfortunatey, I don't remeber who did it. Also, if you go with a T-5 look for a World Class T-5, they came in Cameros, Firbirds, Thunderbirds and Mustangs. They're build sturdier than the ones in S-10s and Chevetts. They also cost more.
You can also check with a guy in Lexington, NC named Clint Bivens (Clint's Auto Parts). He has dozens of flatheads stored in an old school bus in his back yard. I bought a flathead block from him last year. Telephone is 336-787-4136. Ask for Clint. He'll probably charge around $120 for it, plus shipping.
I'm afraid you'll need the 53-only (53-54 in Canada) F-1 bellhousing with the provisions for the motor mounts (rear mounts) on it. None of the earlier models will have that.
If you do have to swap out he Bellhousing, make sure you get the starter plate along with it. There are several different plates out there and they don't always mix and match.
Kevin - Not sure this'll help, but I've got a tranny with its bell housing that I'm sure is a three speed (was a column shift) that came out of my 53 MH F-250 donor. The linkage must have busted so they jury rigged a floor shift set up. You can have the thing if it helps you. I've got the column too for that matter. And I'm probably closer to you than anybody. I don't know for sure whether the donor was an 8 or a 6 though, but I think it was a 6 based on what was left of its motor mounts. He's some pics if you can make any sense of it. Let me know. Stu
Man, I'll bet he could do some real speed-shifting with that set-up!! I wonder how many times they hit reverse instead of 2nd???
Seriously, that looks like a V8 pattern but I don't know exactly what the 6's looked like. It does have the mounts you'll need. I didn't realize the 53-56's didn't use the same type of clutch release fork and linkage that 48-52's did, that is really different. It looks like a Chevy setup.
I dont understand the problem unless you are going for an original restoration.
You can use a wide variety of transmissions by fabricating, or modifying, a transmission mount, Ive even used Brand C at times. Then you would have a choice of various car or truck 8BA bell housings from 48-53 and Ford transmissions into the 60's.
Frankie is a daily driver I am attempting to build out of my various parts trucks. If I can find a '53 F-100 flathead bellhousing, I will have a complete drivetrain for it. I already have a light duty three speed tranny, clutch disc, pressure plate and driveshaft. So, this is the easy way out. It has nothing to do with originality. Just trying to make use of parts I already have.
Yes, I could put a newer tranny behind the flathead. From research I've done it would require fabricating/purchasing an adapter plate and crossmember, locating a tranny, custom shift linkage, custom driveshaft, etc. Sounds expensive and time consuming and I am trying to do this as cheaply and efficiently as possible considering I am also building a show truck.
I don't have any books that new but what are the actual gear ratios for the 3 speed and 4 speed? Most of the difference in the 48 - 52 is the granny first and the rest of the gears are close to the same.
1948-52
3 speed light 4 speed heavy
1st 2.78 2nd 3.09
2nd 1.62 3rd 1.69
3rd 1.0 4th 1.0
I am not sure wher that leaves you with other parts if you had the rest of the drive train pieces that might leave you with needing a drive shft.
