Air breather adapter
Old May 5, 2006 | 01:43 PM
rmalottwtes30's Avatar
rmalottwtes30
Im having some trouble with my air breather, the PLASTIC adapter I have to go from the size of the breather to the size of the top of my carb is broken and bowed really bad and could be like a half inch taller. Is there any place I can get maybe something other than plastic?
Old May 7, 2006 | 10:57 PM
fmc400's Avatar
fmc400
MSEE
I really don't know if this is what you're looking for, but a lot of auto parts stores have a row of this brand called "Help!" and they have a few common PCV routing parts sometimes.
Old May 8, 2006 | 12:12 AM
Torque1st's Avatar
Torque1st
Posting Legend
Salvage yard, but most will be in the same shape, or have someone make one from some aluminum plate. I made one for a VW from some fiberglass body scrap that was about 3/16" thick.
Old May 18, 2006 | 01:17 PM
73Custom's Avatar
73Custom
Is this a factory part? Sounds like the carb or air cleaner has been changed, now they don't fit together? Might need to look for a different air cleaner - that would be the best fix...
Marty
Old May 18, 2006 | 05:18 PM
Ford_Six's Avatar
Ford_Six
The only ones I can find online are the same Mr. Gasket type plastic things, with no height options. What air cleaner are you adapting to what carb?
Old May 18, 2006 | 06:07 PM
LxMan1's Avatar
LxMan1
Holley used to offer spacers. I have one so that my drop base 4" will clear my Edelbrock 750. All V8 Fords have the same size air cleaner ring. 5 1/8" maybe?
Old May 18, 2006 | 06:38 PM
rmalottwtes30
YEa I got a pack of those air filter adapters out of Advance auto. The air breather is also one of those aftermarket I believe edelbroke or holley. Cant remember and its pouring so Im not going outside!!! EVerythnig would work if the end that fits over the carb was a tad bit taller.
