Modular V10 (6.8l)
Difference between 275 hp and 310 hp?
Old May 5, 2006 | 01:10 PM
homecan's Avatar
homecan
What are the differences between the 1999 275 hp engine and the 2000 310 hp engine? Can I upgrade without engine swap?
Old May 5, 2006 | 01:15 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
At the very least, the heads are different. The '00-up heads have a "PI" cast into the sides which means Performance Improved.
What all is involved in upgrading a '99 to '00-up 2-valve HP/trq, I'm not completely sure.
At the very least, the heads, probably the intake.
Old May 5, 2006 | 01:20 PM
krewat's Avatar
krewat
Oh, and certainly the computer would have to be changed, or at the very least, re-tuned... easier to get a 2000-up computer though.
Old May 5, 2006 | 01:26 PM
biz4two's Avatar
biz4two
About 35 hp...
Just kidding, but it was wide open for it.
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old May 5, 2006 | 02:17 PM
captchas's Avatar
captchas
Guest
heads,camshafts. timeing and lift. and who knows
Old May 5, 2006 | 03:50 PM
homecan's Avatar
homecan
Thanks for the info. Engine is in a class A motorhome. I've added Thorley headers. Just looking to maximize performance for towing.
Old May 5, 2006 | 07:39 PM
krewat's Avatar
krewat
Some have thought that the '99 could be brought close to the '00 performance with exhaust, intake stuff and a chip. Whether or not you can get a chip/tuner for the '99 motorhome, that's a different story
Piece of trivia I picked up in my 2001 service manual today: Did you know that the 5.4's left and right banks have different valve lift? Slightly, but it's there, and spec'd.
Old May 8, 2006 | 07:14 PM
devildog_0431's Avatar
devildog_0431
I put a '2000 V-10 in my '99 F-250 a while back....so I got the 310 hp cuz it has PI on the heads, haha yay. I kept the same Computer...had to change a Connector Plug going under the intake to match my Wire Harness...she runs great...no codes. I did notice that that '00 motor didn't have an EGR Valve on the Driver Side Exhaust Manifold so I had to swap Manifolds to have the EGR on my motor. '00 had the EGR Inlet plated off too on the Throttle Body....quick fix. There are only 3 things to be changed on that motor.
The Blue Plug Connector on the Back
Install your EGR Valve on the '00 if u keep the 99 Computer
Run Heater Core Inlet to front of Intake Manifold rather than the Back on the '99
Old May 8, 2006 | 08:59 PM
krewat's Avatar
krewat
devildog, that's great info which I'm sure I'll either forget immediately or remember for the rest of my life - I'm betting on the latter.
Did you notice a power increase and if so, can you quantify it somehow?
thanks!
Old May 8, 2006 | 09:22 PM
cc322's Avatar
cc322
What are the differences between the 1999 275 hp engine and the 2000 310 hp engine? ?
I would say 35 hp
Old May 8, 2006 | 09:50 PM
devildog_0431
I did notice a power increase, she's alot louder, better pick-up, and sucks the hell out of gas, LOL.
Old Dec 6, 2008 | 07:31 AM
dzdiggin'dude's Avatar
dzdiggin'dude
Found this one for you guys to look at. Saturday paper isn't here yet so I was reading some old threads. Any info helps.
Old Dec 6, 2008 | 08:34 AM
Johnny Langton's Avatar
Johnny Langton
All you gotta know is the strategy of the PCM. A simple read of the strategy will yield the right base to tune from.
As for the cams,I've seen that stated about the 5.4L cams as well,but I don't buy it. I've actually measured the lift on several sets of cams from 4.6L and 5.4L engines and they are all identical in every way. The minimal differences in lift, duration, and LSA are,IMO,simply manufacturing tolerances.
JL
Old Dec 6, 2008 | 11:55 AM
krewat's Avatar
krewat
Wow, 2006, and I don't even remember making that post - JL to the rescue again
Old Dec 7, 2008 | 10:32 AM
GT4point6's Avatar
GT4point6
If the V10's are like the 4.6 when the PI heads came out, the intake will bolt up but not match as well as a PI intake which could cost you a little power.
On the up side, the NON-PI 4.6 motors had a larger combustion chamber and a small dish piston.
4.6 PI motors have a smaller combustion chamber with larger dish pistons.
Put PI heads on a NON-PI block and your compression goes up to about 10.5:1 and you get more than the 35HP increase due to the additional compression. 4.6 was rated at 225 NON-PI/260 PI (35hp).
Common swap in the mustang world and you have more power than a stock 260 rated 99-04 PI. Those who do this, usually don't don't tune it unless there are other mods (cams, head work, NOS, boost, etc...)
