New Vibration
Old May 5, 2006 | 12:47 PM
VinnyDiesel's Avatar
VinnyDiesel
New Vibration
Hi guys! I'm new here and I've got a problem. I own a '00 PSD 4x4 and I just got this vibration and a strange noise to go with it. It is there when I am stopped in drive or traveling at about 30 mph. If I put in park the vibe goes away, also if I hit the throttle while moving it goes away. I have tried reading through the older posts but I couldn't find anything that had the vibe at a stop. Hope you guys can help
Old May 6, 2006 | 10:21 AM
VinnyDiesel
Oh, and it also comes and goes. It happened after a night of back road driving, while hitting 4 or 5 rather large potholes. It all started the next morning.
I thought it would be something with steering because it sounds like a steering clunking, or brakes that are kinda letting go at the stop.
The best i can describe the noise is that it sounds like a really big Geiger Counter!
Old May 6, 2006 | 11:11 AM
PSNut's Avatar
PSNut
How about your exhaust system? Any loose components?
Nut
Old May 7, 2006 | 12:17 PM
VinnyDiesel
No, I'm pretty sure thats not it. I've checked 3 times now but I can't find anywhere it would hit. But I guess it doesn't hurt to look again, eh?
Old May 7, 2006 | 01:09 PM
PSNut's Avatar
PSNut
Ya got me stumped
Old May 10, 2006 | 04:32 AM
AustinS's Avatar
AustinS
It could also be a transmission control switch or sensor or even a torque converter problem. They are tough to troubleshoot. My buddies had closely matching symptoms you describe, and drove him nuts for months. If all is quiet in park, but noisy when in gear, its worth a look.
Good luck to you,
Austin
Old May 10, 2006 | 06:22 AM
GeoffNJ's Avatar
GeoffNJ
Vinny, is it a vibration or a rattle? Does the truck shake or you can just hear it?
If the truck shakes, try changing your oil first. Then try fuel additives and possibly the HPX line.
There are people on here far more qualified to answer your question. I'll try the lower echelon answers first.
Old May 10, 2006 | 10:27 AM
dave at BD Power's Avatar
dave at BD Power
Former Vendor
Hey Vinny, have you checked U joints?
Just a thought... I do have many dealers and distributors through-out US and Canada that are very experienced with these diesels, if you are interested in me referring you to a local BD dealer provide me with your zip code and I can see who I have near you.
Hope this Helps
Dave
Old May 10, 2006 | 12:20 PM
VinnyDiesel
truck doesn't shake, just feel vibe in feet on driver and pass side.
After driving it for a week or so, it seems to have stopped unless i'm turning left. This makes the same noise and vibe combo of earlier post, but not when stopped anymore. It is still intermittent.
Old May 15, 2006 | 01:11 PM
bmghost's Avatar
bmghost
On my 2000 F350 I had a similar problem and after a little digging found the rear U joint was bad.
Old May 15, 2006 | 01:48 PM
dave at BD Power
Former Vendor
Check those U joints, the can cause some strange intermittent issue that you wouldn't think would be related.
Old May 17, 2006 | 06:05 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome bmghost to Ford Truck Enthusiasts!
…..See you on the boards.
