Wires!
Old May 4, 2006 | 09:39 PM
79f-250custom's Avatar
79f-250custom
Wires!
hey guys,
on my truck i had a 8 round and i need a 7 flat. so today i was trying to wire the new 7 flat to my truck and can only get the back lights on my trailer to work. no running lights and no brakes.
and in the prosses my clearence lights on my wheel wells went out. on both sides but all my other lights work. what happend to them? they worked before i started to do this. what should i check??
and if anybody knows what color wire does what that would help me out a lot!!!!! i have 3 of the 7 wires on and working right now, the brake lights and both turn signals.
thanks for any help
Mitch
Old May 4, 2006 | 11:01 PM
1997F-350's Avatar
1997F-350
the cover over my plug has all the wires listed i can get colors tomorrow. its dark now.
you probably blew a fuse or have something grounded out back there.
Old May 5, 2006 | 09:47 AM
Brians97F250Crew's Avatar
Brians97F250Crew
yea definately check your fuses under the hood!! ... I put a new connector on mine and the prev owner had blown every fuse under the hood for the trailer lights.
Old May 5, 2006 | 10:05 AM
79f-250custom
thanks alot guys
do you know what fues i have blown?
thanks again and those colors would be great to know.
Mitch
Old May 5, 2006 | 12:50 PM
Brians97F250Crew
No ... I don't know the numbers off the top of the head. Just look with a flashlight so you can see them well .. it'll be obvious. Or look in the owners manual if you have one it's in there that's where I found it.
Old May 5, 2006 | 01:20 PM
1997F-350's Avatar
1997F-350
trailer lights wiring diagram
under hood fuses
under hood fuses 2
and if i am not mistakin the in cab fuses have a label on the back of the cover you remove to access them.
good luck ryan
Old May 5, 2006 | 01:48 PM
79f-250custom
thanks alot man. your a life and a headache saver. ill go hook it up right now. thanks for taking the time and drawing out the pic, i appreciate it!
thanks again guys
Mitch
Ridenred333
Apr 19, 2013 10:18 AM
jerem0621
1997 - 2003 F150
Feb 18, 2011 11:17 AM
Jbailey52
Electrical Systems/Wiring
17
Mar 12, 2008 05:37 PM
rebel_ford4x4
All Things Towing
Nov 12, 2006 10:32 PM
EPDP99
Nov 6, 2005 04:33 AM
