Modular V10 (6.8l)
V10 Stalls - No Warning
Old May 15, 2006 | 09:36 PM
Rcoy27's Avatar
Rcoy27
V10 Stalling
I joined this forum because my 92 V10 started stalling after filling with gas and taking my wife to pick up some furniture. It started stumbling when I started it and then would die. Happened several times and I read on here to try some Lucas? gas treatment. It worked and it started running fine after a few miles with the gas treatment in it. Although yesterday it died on me when I shifted from drive to reverse. Still ran smooth and have no idea why it died. I tow a >10,000 5th wheel and have a 3.73 rear end. It pulls great but I get a little nervous when I get it up to 4 grand. I'm amazed that some of you run it up to
>5 grand. This is a great forum.
Old May 15, 2006 | 10:11 PM
BareBones's Avatar
BareBones
Scottay - Mine died as you described about every month to six weeks. Always as I came to a stop, and maybe also at a slight elevation. Under warranty, the throttle positioning sensor was replaced and the problem went away for good.
Another characteristic in my case was that the engine at idle wasn't rock solid, but would vary some, maybe a hundred rpm. Also, after dying, the engine would fire right back up, except that its hard to do that when you're also trying to make a right turn in traffic with a dead engine and no power steering!
Old May 15, 2006 | 11:59 PM
biz4two's Avatar
biz4two
Thumbs up
Originally Posted by Scottay
At the risk of being naive, what is the IAC and what does it control?
If you would like pictures with instructions of the IAC removal and install...take a look at my gallery. Here is a link...hope this helps.
https://www.ford-trucks.com/user_gal...&albumid=22274
biz
________________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old May 16, 2006 | 03:54 PM
ken04's Avatar
ken04
Originally Posted by captchas
it's called the idle air control valve and after time they tend to stick. esp. when the throttle body carbons up. with that i would take the tb off and with a can of choke/carb cleaner clean all the black crude out and off it .
this would be my first guess also. Mine did this occasionally when cold. If I brake for a light or stop sign before it's warm it'll stumble and try to die. I cleaned the IAC and it went away.
Old May 17, 2006 | 09:50 PM
captchas's Avatar
captchas
Guest
my 05 would also stall from time to time going to stop. turned out the 05's had a tsb that needed a reflash and a new tps on the tb. took the tech all of a 1/2 hour to do it all.
a place i'm turning to now is www.motorcraft.com
click on tech resources then bottom left side purchase . for 10 bucks got me 72 hours of research time. down loaded my manuals all of them in pdf. all the tsb's to date. the wireing diagrams .got a oasis report on my truck and a heck of a lot more. when i did go into my dealer to get the truck repaired the tech came out said thank you .you just saved me a 1/2 day of researching. i just drove your truck it's perfect .now how about we go for a drive together to verifie how it feels with you driving. dead on repair . a very good 10 buck 's spent
Old Jan 12, 2019 | 10:15 AM
William Alford's Avatar
William Alford
Kerwat: I have a 2002 Excursion with 111,000 miles, It has astalling problem. Shorty before the stalling begins the vehicle shutters a little. Tome, this seem like a fuel system problem, but I have had that system throughly gone over. I think the problem is electrical in nature, can you help me as I do not want to trade away this vehicle
Old Jan 12, 2019 | 01:33 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Was the fuel pump relay changed?
Old Jan 12, 2019 | 01:36 PM
William Alford
Fuel Pump
[QUOTE=Krewat;18414026]Was the fuel pump relay changed
No it was not, but the fuel system was inspected for issues, none found
Old Jan 13, 2019 | 07:29 AM
tiffy2000's Avatar
tiffy2000
IAC removal guide not found
Old Jan 13, 2019 | 05:29 PM
William Alford
IAC
What does IAC mean
Old Jan 13, 2019 | 06:26 PM
krewat's Avatar
krewat
Idle Air Control - it's a servo that the computer uses to adjust the idle.
Old Jan 13, 2019 | 06:29 PM
William Alford
Thanks, seems from what I’ve read the IAC and the fuel pump relay might be the culprits to my stallingissue, thanks
Old Sep 19, 2022 | 04:25 PM
  #28
craighunter78's Avatar
craighunter78
6th Gear
i am having the same issue, stalling. what is the fix for this?
Old Sep 24, 2022 | 08:19 AM
  #29
bajaphile's Avatar
bajaphile
Best to start with your model year, application, mileage and any other relevant information... I feel like I say this a lot on these threads, but it sure seems like the fuel pump system is a very common culprit in these trucks...Seems like most of the time the pump itself is starting to fail, or it is the fuel pump relay. With 2005+ model years, you'll have the fuel pump driver module to check as well.
hambass
Nov 23, 2022 08:02 PM
dclinton
May 28, 2021 03:54 AM
landk00
Aug 11, 2016 12:30 AM
buckeyebronco
Dec 22, 2015 02:02 PM
gary.aderhold
50
Dec 11, 2015 05:48 PM
