1978 - 1996 Big Bronco
ball joint press
Old May 4, 2006 | 03:11 PM
RA81222's Avatar
RA81222
ball joint press
Just wanted to make sure how the ball joints press into the knuckle.I saw procedure for pushing them out, but do they press in from the bottom up into the knuckle or do you press them down in from the top.I was not sure if the nut was put on the threads and that was used to push them down in.Sorry if this seems like a silly question.
Old May 4, 2006 | 03:49 PM
blackened's Avatar
blackened
you just work the threads in from underneath the knuckle and then the castle nut tightens it into place until you can fit the cotter pin through.
Old May 4, 2006 | 09:04 PM
RA81222's Avatar
RA81222
I thought you needed the press to push them back in the knuckle?I guess I'll figure the press out when I borrow one.
Old May 4, 2006 | 09:15 PM
topfisherman's Avatar
topfisherman
Yes, you need the press to push them back into the knuckle. The press will come with different size "cups" that you fit onto the ball joint body to push it in from the top. You DO NOT want to press the ball joint in from the threads, only from the body of the ball joint.
Old May 4, 2006 | 09:16 PM
andym's Avatar
andym
You push the ball joints into the knuckle through the bottom.
When you press them out, the bottom one comes out first, then the top one. Installation is the reverse. If you listen to blackened, you'll screw up your ball joints if you even overcome the frustration of attempting it that way.
Old May 4, 2006 | 11:20 PM
blackened's Avatar
blackened
im glad i sold that truck...
Racerguy
1997 - 2003 F150
214
Jun 10, 2025 07:58 AM
Wicked Endings
Aug 22, 2010 06:23 AM
MikeMcCasland
Nov 29, 2009 09:50 PM
vze2sgxa
Sep 17, 2008 05:28 AM
kjett
May 7, 2004 03:26 PM
