temp gage not reading
Old May 4, 2006 | 11:30 AM
98xlt's Avatar
98xlt
The needle on the coolant temp gage did not raise up at all today on my 98xlt during 1/2 hr drive to work. Usually the needle will read about 1/2 way up after about 4 minutes of running from cold. It does not appear to be overheating at all. suspect temp sender. Thermostat itself is about 3 yrs old. Any advice?
Old May 4, 2006 | 01:21 PM
87 XLT's Avatar
87 XLT
As far as I know your 98 has the standard Ford single wire sending unit & if you remove the wire from it & ground it the gauge should read full hot.
Old May 4, 2006 | 02:35 PM
98xlt's Avatar
98xlt
thanks. do you know where that sensor is located? I'm going to drive it some distance this afternoon. on the chance the t-stat is stuck open I still should get some temp rise in 30 miles unless it is the sensor I think.
Old May 4, 2006 | 03:23 PM
87 XLT's Avatar
87 XLT
Should be near the t-stat housing. Red/white stripe wire.
Good point on the T-Stat, it could be stuck open, but I think they usually stick closed.
Edit
Is the heater blowing as hot as it normally does?
Old May 4, 2006 | 08:56 PM
98xlt's Avatar
98xlt
heater is definitely not blowing as hot as it should. also on my trip, needle rose to just above the "C" mark rather than half way up the scale.
Old May 4, 2006 | 09:35 PM
87 XLT's Avatar
87 XLT
Looks like a bad T-stat then.
tractormanbill
Aug 5, 2014 01:25 PM
Joejoecat
1983 - 2012 Ranger & B-Series
Aug 25, 2012 08:12 AM
schloss
Electrical Systems/Wiring
Oct 1, 2008 11:08 AM
thedaddycat
Aug 1, 2007 09:48 AM
kenf1948
Jun 5, 2001 11:23 AM
