Gas Gage
Old Aug 24, 2012 | 04:30 PM
Joejoecat's Avatar
Joejoecat
Gas Gage
1999 Ranger XLT . Gas Gage needle points to "full" all the time even after the the truck is shut down . Any thoughts ? Thanks
Old Aug 24, 2012 | 06:33 PM
Phinxter's Avatar
Phinxter
I'm not sure how your truck electric system works but when I shut mine off wherever the needles are on all the gauges is where they stay until I start it up again. The way to test your fuel gauge to see if it is operating is to unplug the connector at the pump, the gauge should go to E. Then you would ground the + wire for the fuel level sensor to chassis ground and it should sweep to F. My guess if it wont goto E unplugged is either your gauge is bad or the signal wire is shorted someplace. if it is ok then suspect your level sensor
Old Aug 25, 2012 | 08:12 AM
pawpaw's Avatar
pawpaw
Did this problem come about slowly over time, or suddenly after some event???
Is the yellow "Check Gauge" warning light lit???? Any other gauges acting out???
Been having any electrical problems with the dash gauges, battery, alternator lately????
Try thumping the instrument panel to see if the gauge is just stuck.
There is a "slosh module" on the back of the instrument panel fuel gauge circuit thats supposed to dampen/average out/slow down, the gauge reading & it sometimes acts out & causes gas gauge problems.
If you come to suspect the in tank fuel level sender, do a search for "slosh module" & in one of the posts will be ohms readings for the fuel sender that you can use to check the sender out, or sub resistors at the tank electrical connection to cause the gauge to read full, empty, 1/2 full, ect.
If you've recently used a tank of out of spec fuel with too much sulphur in it, it can cause sender electrical contact problems & Chevrons Techron Concentrate Plus in the 20oz size in the tank at the pump before filling, so we get good mixing, claims it'll remove the sender contact corrosion.
If still no joy with the gauge, at least the Techron will tidy up the fuel injectors, intake valves, piston crowns & combustion chamber deposits, so it'll at least do something for the gold spent!!!
More thoughts for consideration, let us know what you find.
BK834
15
Jul 10, 2017 12:07 AM
BigDan1
18
Mar 26, 2016 08:28 AM
Idlewild24
Jun 3, 2014 11:55 PM
oldblu65
16
Aug 11, 2009 05:52 PM
lymo
Dec 7, 2003 01:35 PM
