'67 window problem
Old Jun 11, 2002 | 01:22 PM
olddawg's Avatar
olddawg
'67 window problem
Old Jun 12, 2002 | 03:42 PM
Laddman's Avatar
Laddman
'67 window problem
Hey folks
I've got a '67 F100, and my driver's side window has stopped working.
from what I can tell, i need a new regulator/gearbox, keep hearing different terms from different folks. they're manual windows. The shaft for the handle is ok, but the internal gears are not. I can't seem to find a replacement to save my life, so i'd appreciate any ideas on alternate parts, if you have one layin around, or anything.
Thanks,
Ladd
Old Jun 12, 2002 | 03:58 PM
user 5363849's Avatar
user 5363849
Post '67 window problem
Too bad, I picked up a pair of window regulators from a Pick N Pull in Fairfield CA. I ended up not needing the passenger side.
But they're out there in the wrecking yards. I had my choice of a few trucks. I always look around to see which one already has other parts out of the way. However, finding a really good, tight one is tough, mine had a bit of play in the shaft, but it does work otherwise.
Don't know if you messed with them, but they come out and go in really easily. The tough part is not messing up the interior door panel when you pop off all of the little clips that keep it on.
If you're not familiar, pry on the clip and not the door panel.
Old Jun 12, 2002 | 04:08 PM
BB's Avatar
BB
'67 window problem
Ladd, the '67 window regulators are different than the '68-'72 window regulators. I'd post some pics but something is wrong with the User Gallery today.
Barry
Laddman's Avatar
Laddman
'67 window problem
thanks for the info.. I've called the local yards.. I guess I'll have to start driving into the junkyard district across town.. I've already got the door apart, with no damage, thankfully.
Ladd
Old Jun 12, 2002 | 05:19 PM
buzzard's Avatar
buzzard
'67 window problem
Those things are on Ebay all the time.
Old Jun 15, 2002 | 07:21 AM
GolferSA's Avatar
GolferSA
'67 window problem
They're on eBay RIGHT NOW!
