Need Help 37K and Broke
Old May 3, 2006 | 07:55 PM
Talonman's Avatar
Talonman
As luck would have it I just rolled 37K and my reverse sensing and power sliding window both failed.
I checked the fuses and they are fine. The reverse sensing off light stays on most of the time. the rear window won't move. On the bright side the window is closed.
This is my first Ford product and I do like the truck, but this is really stuff that happens to your buddy.
I'm a do it yourself kind of guy so any repair manual recommendations would be helpful.
Thanks
TM
Old May 3, 2006 | 08:20 PM
hllon4whls's Avatar
hllon4whls
Id get a manual and see what the common thread is. Might be a loose ground. Probably something simple. I check every fuse in the box with a test light.
I am assuming that you tested the fues with a light or a meter? I have had 1 fuse look fine but be wide open.
Old May 3, 2006 | 09:54 PM
DonsFx4's Avatar
DonsFx4
Talonman...my '04 WDM shows nothing in common with these 2 systems...different power sources and different grounds.
The rear slider motor has a circuit breaker (not a fuse) mounted on it. It's possible that's tripped. Problem is gaining access...it's smack in the middle of the rear wall, so you'd have to remove the rear seat backs to get to it. The connector has 2 wires that alternate between hot or ground, depending on slider window switch position. If switch is "Open", the Red w/ Yellow stripe wire would be hot, and the Yellow w/ Lt Blue stripe wire would go to ground. If the switch is "Close", it would be the reverse.
Either reset the c/b and try it, or it might be a motor change. Power for the slider window comes from fuse F2.401 30A, located in R/H kick panel fuse box.
For the reverse sensing...the Parking Aid Module is located in the L/H kick panel above the emergency brake. I'd check the connector to make sure it didn't get knocked off somehow. Also, the disable switch in the center instrument panel might be stuck. If it is, you'll get continuity across pins 1 and 2 of the male connector on the switch assembly itself. (On the female connector, pin 1 goes to a Black ground wire, pin 2 goes to a Dark Green w/ Violet stripe wire). Power for the system is fuse F2.18 10A, located in the R/H kick panel fuse box.
Hope this helps...I can't think of anything else!!
Old May 4, 2006 | 07:10 AM
ford9c's Avatar
ford9c
The motors for the power sliders have a history of going bad especially if they sit idle for too long. Something about condensation corroding motor internals.
Old May 4, 2006 | 08:05 AM
New2004Lariat's Avatar
New2004Lariat
If you're only 1k out of warranty, why don't you take it to the dealer and ask nicely if they could help you with an after-warranty adjustment? Did you have regular maintenance performed by the dealer? If so, I bet they'll help you out.
Old May 4, 2006 | 06:09 PM
Talonman's Avatar
Talonman
Great support guys...thanks. DonsFx4 I will check it all out. I will try the dealer but I recently moved to a new state, it's woth a go should DonsFx4 information not be fruitful.
Thanks again.
Also I am looking for the OEM manual does anyone know where I can find it?
Old May 4, 2006 | 09:27 PM
DonsFx4's Avatar
DonsFx4
Talonman...I think the top-of-the-line are the manuals from Helm, but they are like $170.00 for the maintenance manual. I got their wiring diagrams for $60.00 plus shipping ($7.00). The diagrams are dead-on...all the wires are identified and color-coded correctly (from what I've worked with on my truck so far).
I looked and found Chilton's has an on-line manual for the 2004 and up F150, costs $19.95/year, but can't vouch for accuracy.
http://www.chiltondiy.com/index.aspx
I didn't see any 2004+ hardcopy Chiltons in my local Poop Boyz, but'll keep looking.
