Vibration Help Please......
Old Apr 16, 2006 | 06:17 PM
DASTUD's Avatar
DASTUD
My Back Right Door Has This Annoying Vibration That Just Started, I Can Open The Door And Knock On It To Produce The Vibration. I Am Sure I Can Fix It, I Just Need To Get The Inside Door Panel Off. Any Help?? I See The Two Small Bolts At The Bottom, But I Still Cannot Pop Off The Panel. I Do Not Want To Break Anything. Thanks In Advance For Any Advice. Man, Vibrations Suck!!!!!!!!!
Old May 4, 2006 | 10:58 PM
amish77's Avatar
amish77
Check for some around the underside of the door handle. I'fe been fooled by those before. Look for anywhere that a small circle of plastic is. There's probably a screw behind that. Most of the bolts are around the handle. If you've got manual windows, there's a clip that holds those on as well. Other than that there's a system of "pops" that holds the edge of the truck on. Take your time and use some prybars for these. If you use too much gusto you can crack the door panel, so go easy. Other than that I've got nothin'.
