Axle Seal leaking
Old May 3, 2006 | 05:37 PM
polcat's Avatar
polcat
Axle Seal leaking
Looking for Ideas or suggestions?? I have replaced my left axle seal about 3 times and it will go a little while and start leaking again. I have new axle bearings on both axles but am only having problems on the left side. I originally found a little burr on the axle and used emory cloth to clean it up. Do they make a sleeve or a another seal that is better?? part numbers?? I have a motor bearing seal with single lip spring on it. And yes it is installed correctly. any suggestion will help??
Old May 3, 2006 | 07:22 PM
barry's Avatar
barry
Is there a groove worn in the shaft at all? Even the slightest line will cause a failure. You may have to measure the shaft and see if you can get a speedi sleeve from a good auto parts store.They make sleeves in many different sizes and lengths. When you spin the shaft, there's no wobble? That would cause a failure after a while. Also, make sure your vent on the rear is clear. If it's plugged,This will build up pressure and cause a seal to blow out.
Barry
Old May 3, 2006 | 11:19 PM
6T6Shorty's Avatar
6T6Shorty
Axle Seal
I too am having problems with the left side. My 66 has a Dana 44 (Oem Ford eqivalent)I know this seems odd as it wasn't until 68' that they should of been in that truck so I'm told. I have an inner seal then a tapered bearing and then an outer grease seal in the retainer. after packing the bearing the grease seems to be passing thru the retainer into the drum as it heats up. If this is the same problem as you please post if you find a remedy!!
Old May 4, 2006 | 05:27 AM
jowilker's Avatar
jowilker
Barry is spot on. I had the same problem too, and finally had to put silicon in the housing to stop a new axle seal from leaking. It's funny to me to see how rubber had cut a groove in a metal axle.
Make sure that you don't have oil on your brake shoe material.
John
Old May 4, 2006 | 01:41 PM
bertha66's Avatar
bertha66
Barry is on the spot about the vent, that was what my 66 4x4 was doing, lost 2 seals before I fond the plugged vent.
Old May 4, 2006 | 04:34 PM
polcat's Avatar
polcat
That is weird you have a dana 44 in your truck. mine has a 9" so the seals are different. i am going to a attempt to see if i can get a speedy sleeve to install. These part houses around here really suck!!
Boba Fett
Apr 28, 2013 06:09 PM
nct53
Nov 7, 2011 02:12 PM
1975Ford
15
Nov 21, 2005 11:19 AM
peterdroy66
Oct 3, 2002 03:35 PM
tom100
Aug 25, 2001 08:11 PM
