Pulleys and brackets?
Old May 2, 2006 | 10:43 PM
justine's77ford's Avatar
justine's77ford
got a new/used 460 for my 77 ford camper special. when swapping engines, noticed the pulleys and brackets were different. originally had the crank pulley w/ 2 grooves. the other has 3 grooves. wondering if these pulleys are interchangable. the 3 groove is noticalby bigger and heavier. both blocks are D1VE blocks. the 3 groove pulley has part # D5UE. not sure what other pulley is. Also got the bracket D8UA for the flat power steering pump but the steering pump line won't attach to my steering w/ out serious bending. having a hard time lining up the power steering belt with the pulleys i have. should i use the flat power steering pump or the round power steering pump. What's the difference between the U and the A in the part numbers
Old May 3, 2006 | 10:06 PM
justine's77ford
does anyone have pics of the belt diagrams for the older 460's. tink mines a 78.
i'm guessing because both motors are internally balanced, it shouldn't matter what pulley i use.
does the "U" mean that the part came from a Van 460? Please help or direct me in the right direction. thanks.
Old May 4, 2006 | 11:32 AM
RTM's Avatar
RTM
The car set up will have a saginaw PS pump and the truck set up will have the plastic housing PS pump. These are different brackets all together. All I can add for the PS belt is that it should run around the water pump pulley as well. I have a 85 or 87 460 with all of the brackets on it but the PS pump is long gone. not sure if a pic it will help or not.
