90 Bronco--Won't Start
--will turn over but won't hit or even try to start
--hear fuel pump running but no pressure on fuel rail. Cannot get anything out of the schrader value. Maybe pump hasn't ran long enough to fill rail system.
--pull codes and get 41,62, 87, Check ineretia switch and it works. switching will turn off pump or I don't hear it running at that point
--put gas into intake and it won't hit, plus pulling plugs I find no spark
--12 volts to coil
--changed out ignition module on dist and nothing.
What else can I check before I start replacing parts, one by one.
Oh how I wish for points and 4-barrel carbs. Now those were the days!!!!!
Code 62 is a failed 3-4 shift solenoid or a problem with the circuit to it in the E4OD transmission.
Code 87 is most likely your problem. If the inertia switch is not tripped, check for battery voltage at the fuel pump relay (12VDC approx.) No voltage = dead inertia switch. Voltage but still Code 87, check the wire from pin 22 of the ECA (EEC-IV computer behind the passenger kick panel) to the FPR (fuel pump relay). If there is voltage at pin 22 of the ECA, Resistance between the FPR and pin 22 on this wire must be LESS than 5 ohms and it must NOT be shorted to ground or power. If the wire tests good, replace the FPR. The wire in question should be LT. BLUE w/ an ORANGE trace. If the problem/Code 87 persists, you may have computer problems that necessitate replacement.
Points are the suck and carbs too. Carbs can be just as much a pain just gotta know how to trace these problems. Electrical grimlins can be so frustrating.
Also, I can hear the pump running but I agree it could still be bad or pumping at low pressure.
on the points/carb--was much easier to trouble shot-
I will look at it tonight and ck voltages-and thanks.
