Tachometer not working
Old May 1, 2006 | 09:02 PM
cuttressb's Avatar
cuttressb
1985 f250 6.9 ltr
Where is the tach sensor located? My tack does not work at all anymore. It used to come on when I turned my heater fan on. Don't know if it was a short but I did not notice any other problems with electrical. Is there a way to test the sensor or jest replace it and hope that's what's wrong.
Old May 2, 2006 | 12:01 AM
Dave Sponaugle's Avatar
Dave Sponaugle
Here you go.
Old May 2, 2006 | 05:25 AM
PLC7.3's Avatar
PLC7.3
Replace the tach sender on the oil fill housing a big 1" nut with 2 wires. Ford only part Engine RPM sensor E5TZ-17B384-A about $50. You can remove and clean it but usually changed later too. You can test it too, hold it in the air away from ferrous metal, using an ohm meter lead on each wire you need DC resistance between 2000-3000 ohms.
Old May 8, 2006 | 06:01 PM
cuttressb's Avatar
cuttressb
Thanks. Looks like the wire is boke off the sensor right at the nut. Time for a new one.
blackgold50
Aug 28, 2014 08:39 AM
Rentaro
Aug 7, 2014 12:14 PM
Greg5OH
Jul 13, 2014 03:20 PM
nolan62
Jan 9, 2014 02:00 PM
