Will this rearend work?
Old May 1, 2006 | 07:52 PM
idealtrucks's Avatar
idealtrucks
Will a rearend out of a 86 or 87 model truck work in our model trucks? I know the 86 and 87 are different body styles, but not sure which model the rearend is.
Old May 1, 2006 | 10:00 PM
Ford_Six's Avatar
Ford_Six
It would be an 8.8 for an F-150, or a D60 or early sterling 10.25 for the heavier trucks. Neither I'd really want under my truck, and they aren't direct bolt ups.
Old May 2, 2006 | 01:29 PM
Franken-ford's Avatar
Franken-ford
those axles are wider than our series turcks have, i think. I know the very next series after ours has wider axles with different spring perch locations.
Old May 3, 2006 | 05:51 AM
jowilker's Avatar
jowilker
The rears are the same from 73/86 when the 9" was discontinued. To use one on a pre 73 the perches have to be moved inward. Tires will be out closer to the fenders.
John
Old May 3, 2006 | 08:27 AM
idealtrucks
THanks, thats all I needed to know. BTW, why would Ford discontinue using such a popular and strong rearend as the 9"??
Old May 3, 2006 | 09:35 AM
jowilker's Avatar
jowilker
Good question, All of the rear ends that Nascar runs are modified Ford 9". Why Did Ford stop using the FE? One of the best pulling motors ever built.
John
Old May 3, 2006 | 05:57 PM
idealtrucks
Ford has done some very odd things over the years. I think getting away from the twin I beam suspension was a very dumb thing too.
