Lots of starter problems
Old May 1, 2006 | 07:48 AM
86fordfreak's Avatar
86fordfreak
Either i am gettin some really cheap starters, or i am just a dumb *** when it comes to puttung them in. I have gone through 6 starters in the last 8 days. All of them are breaking the mounting ears, and this last one i took off about 10 minutes ago busted the entire front housing that covers the bendex off. I'm not sure where to go from here honestly. I think after all the defective trade ins i have done this week, Advance Auto Parts is about to close there doors to me. Any advise???
Old May 1, 2006 | 11:49 AM
smallblock351w's Avatar
smallblock351w
my advise go to napa for a starter, i went through 4 starters from advance, and auto zone has the same problem. they recondition the nose cones on the starters and cut them to much so the starter slides in to far.
Old May 1, 2006 | 06:44 PM
srercrcr's Avatar
srercrcr
Is it possible the gears aren't aligned right?
Check your Chiltons for any mention of shimming.
Old May 1, 2006 | 07:07 PM
AFSOCmech's Avatar
AFSOCmech
I just went through a similar issue on my 86 with a 300 and manual trans. A few things I noticed was that the starter bolts kept backing out allowing the starter to sit at odd angles (fixed by loc-tite), the steel plate between block and bellhousing was warped from where previous owner apparently used a gorilla to try to tighten bolts down to keep them from backing out (also allowed starter to sit at odd angle, fixed by ball peen hammer) and a lot of wear on the flywheel teeth (fixed by new flywheel). Haven't had a problem since those problems were fixed. The biggest culprit apparently was the flywheel.
Just a few areas to maybe consider.
Old May 2, 2006 | 08:40 PM
BugsB1976's Avatar
BugsB1976
starter problems
i have been having a problem trying to start my truck first my starter was messed up so i had it rebuilt n it kept on grinding when i tried to start it n then i changed the flywheel n it done the same thing grinding bad so i bought a new starter from autozone n it is still grinding when i try to start it n when i had the transmission pulled back i fixed the plate between the motor n transmission so i don't think is the problem but i don't know does anyone have any suggestions and i have tried to put washers between the starter and that plate on the motor
Old May 2, 2006 | 09:36 PM
srercrcr's Avatar
srercrcr
That has to be the longest sentence ever written.
Old May 2, 2006 | 11:42 PM
tomas428's Avatar
tomas428
When i first bought me 85 F150 with a 302 automatic trans. the guy told me that the starter had fallen off thats why he stoped using it, so i went and bought a new starter and got the truck going but i think it was about the sixth time starting the engine with the new starter it broke the ears off again so i got under the truck again looking for thinks that could cause this, the flexplate was good but then when i looked at the bellhousing there was a long crack in it(i have pictures in my gallery), so i took the transmission out got it to a transmission shop they got me a new housing and rebuild it using the internal parts form my old transmission, once i got transmission back in there i took the starter to a starter shop he had a used housing laying aroung so he put that one on there for me and when i installed it i used loc-tite on the bolts and so far i have never had a problem.
Old May 3, 2006 | 09:59 AM
BugsB1976's Avatar
BugsB1976
it tries to start but won't all it does is grinds it acts like the starter is kicking out too far what could it b
Old May 3, 2006 | 01:41 PM
sierraben's Avatar
sierraben
Never had a starter problem (knock on wood).
It's the original starter on my 81 F150 4.9L T-18; but once in awile it does act up a bit.
srercrcr, It was a long sentence that BugsB1976 wrote.
I tried reading it in one breath.
Old May 3, 2006 | 03:56 PM
tomas428's Avatar
tomas428
Are you sure its the right starter for it, becuase there is vehicles that have a smaller flexplate with less theeth on it. When i got the starter for my truck it did the same thing so i went back and he gave me a different starter and that one looks like it has smaller theeth and that one works fine.
Old Aug 11, 2006 | 01:58 PM
flip237's Avatar
flip237
hey ya all /i have the same problem igo to start my truck and i get a grinding sound but than i try again and it start no problem, ask mech he said my fly wheel migth be missing a tooth causing this to happen know and than any body know what else it could be
84StraightSix
23
Sep 9, 2014 08:19 PM
bigfix
Jan 1, 2012 05:39 PM
GonzoCSU
Feb 3, 2010 08:54 AM
IZZYAZ
Apr 29, 2009 08:17 AM
noshoes
Oct 20, 2007 03:06 AM
