1978 - 1996 Big Bronco
quick question about engine idle
Old Apr 30, 2006 | 11:49 PM
blackened's Avatar
blackened
when it says the idle should be around 650 rpms is this in park or drive.
Old May 1, 2006 | 12:07 AM
greystreak92's Avatar
greystreak92
650 is "curb idle" which is at normal op. temp. with the transmission in a non-moving gear.
Old May 1, 2006 | 12:24 AM
blackened's Avatar
blackened
do you know where i can find a throttle body bolt. the jerk off at the junk yard wont let me take bolts off engines
Old May 1, 2006 | 12:37 AM
greystreak92
Um, well as long as you get the same length and thread pitch, you should be able to get the bolt commercially. Probably not at your typical hardware center but a hardware supplier for commercial/industrial applications should be able to match it for you. Or find a different boneyard.
Old May 1, 2006 | 12:55 AM
blackened's Avatar
blackened
having an off idle will cause improper shifting wont it
Old May 3, 2006 | 12:45 PM
evillord_32's Avatar
evillord_32
I had this problem where my techometer said iw as running at 2500 rpm when really i was at 1000. So if anyone knows how to fix it great...i dun wunna buy a new one
Old May 3, 2006 | 02:57 PM
al_huryn's Avatar
al_huryn
Hey that sounds like mine, the tach shows 2500 but it's obviously off because the needle doesn't really go down below that at anytime, anyone know how to re-calibrate the tach or fix that needle whatever the case may be?
