Low Voltage
Old Apr 30, 2006 | 09:23 PM
Keepback300ft's Avatar
Keepback300ft
Low Voltage
93 ranger xlt
I am showing low volts around 10v i guess and my battery warning light is on. It started yesterday but the volts shot up and the light went out after a couple of minutes driving, but today no dice the volts stayed low and the light never went out. My battery is only about 2 years old. Any guesses?......alternator, wiring, battery........
Old Apr 30, 2006 | 09:24 PM
RangerPilot's Avatar
RangerPilot
Well...test the battery with a real voltmeter, then test the alt with a real voltmeter. You can also have them professionally tested at an auto shop under load. Sounds like the alternator is performing at times then cutting out.
RP
Zach
Old Apr 30, 2006 | 09:27 PM
Bdox's Avatar
Bdox
Sounds like classic symptoms of alternator brushes failing. That is assuming that you have made sure all the connections are sound.
