4wd problem please help!!!!
Old Apr 30, 2006 | 07:04 PM
tsi9973's Avatar
tsi9973
i have a 88 f150 4x4 with the 302 and mazda tranny. i just put a 4 inch lift on and 33x12.50's on it. my problem is when i lock the hubs in and put it in 4 hi or lo the tires like lock up and bind, and i can hear this noise from under the truck like metal on metal. it drives fine in 2wd. the front end does not bind even if i have the hubs locked in only when i engage 4wd. i know i need upper ball joints can this be the broblem? or maybe a bad u-joint? or a broken front diff? i dont think the diff is broken because i kock the hubs in and turn the truck off and turn the front drive shaft and everything moves fine. help me!!!!!!!!!!!!!!! one more thing i noticed the radius arms look like the tire is rubbing on them, also i forgot to put the rear bushings on both radius arms. i have them and will be putting them on.
Old Apr 30, 2006 | 07:38 PM
Franken-Truck's Avatar
Franken-Truck
Do you get the same noise and binding if you put it in 4x4 and leave the front end UN-locked? If so, could be something wrong in the Tcase.
Old Apr 30, 2006 | 08:22 PM
tsi9973's Avatar
tsi9973
i havent tried that yet i will try that tomorrow.
Old Apr 30, 2006 | 09:25 PM
DT 466Man's Avatar
DT 466Man
what about the driveshaft on the crosmember?
Old May 1, 2006 | 12:11 PM
minnesota4x4's Avatar
minnesota4x4
I just installed a 6" tough country lift in my '95 F150 Extended Cab 4x4 and had to notch the crossmember for the drive shaft. I also had to grind some of the weld on the drive shaft.
Old May 1, 2006 | 05:43 PM
tsi9973's Avatar
tsi9973
i put the 4 inch rough country on i will check that also.
