what years can i pirate rear leaf springs for my 69 crew..
it has 10 leafs and is 2 1/4 wide...can i use up until the mid 70's
for springs or is 72 the cutoff???
joe
Looks like you need 66-72 F250 4x4 for a direct swap.
Here's a link to a scanned segment from Hollander:
https://www.ford-trucks.com/user_gallery/displayalbum.php?&albumid=1299
I'll add the other swap options to the link in a few minutes.
And I'll rescan to get the whole picture since I hadn't planned on the web title cutting off the top of the scan.
I'd highly recommend buying one of their interchange manuals. Unfortunately, they're about $100 a copy.
If I'm reading the book right it looks like you may luck out and be able to use up to late 1970s by swapping bolts and bushings, as long as it's from a 4x4.
Have a look and see what you think:
