Loose wire problem
wire some where, I went to start it today it turned
over,didn't have the gas so I stopped turning it over,
pushed the pedal a couple times and it did not click
or nothing when I tryed to turn it over,then I tried to
bypass the solenoid and it jes shorted sparks n'stuff,
Is there a common wire that goes loose or a fuse or what,?
I'm stumped cause at first this one wire was coming loose
alls I had to do was pop it back together,then popping it back
together stopped working and I had to rattle all the other connections that worked, and now none of that works...not
even my fist!!!Help is appreciated
the truck is 1970 custom camper/s,390 2bbl,4gear,has some
tape deck in it thats not stock in case that helps to answer
the question,there is also a unconnected orange wire with
no other hookup in sight,Stepping up to super camper special
soon I hope cause inspections got this one
Fe power
Later,
Russell
1968 F250 LWB 300-6
FORD=First on Race Day
MOPAR=Mostly Old Parts and Rust
See if that turns the starter over.
If it still sparks,tap your starter a few times,and try starting again.
If nothing,come back here and tell us.
[font color=red]Dennis
FTE Adminstration
[/font]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
[/font]
>terminal of the starter solenoid.
Dennis, I think you meant the "S" terminal.
Hey your starter might be stuck in the flywheel. Put the truck in gear and rock it back and forth, this may free it up.
Barry
this wire came loose from the engine trying to start,I ve had
it(starter) get stuck before thats different, the two ground wires
at the front turn signals are loose,but I never tightened them
down when I put on another grill,.theres no frayed wires
visible, what about fuses?? the cylinder glass fuses are fine,
I dont know about the big one though..
Fe power
It may even be the starter drive that is causing the problem.
FTE Adminstration
[/font]
[/font]
