Computer gone amuck?????????
Old Apr 30, 2006 | 01:21 PM
Fully_Loaded's Avatar
Fully_Loaded
Question Computer gone amuck?????????
I will make this simple, I am getting code 998 during a KOER test, " Engine Control Sysyem operating in failure mode and Effects Management (FMEM) programming strategy" Has my puter kicked the bucket? The truck runs but it will idel up and down one time about every 2 min or so and I get an intermitent miss above 3000 rpm occasionally. Also the colder the outside air temp. the harder it is to start. Any ideas?
Old Apr 30, 2006 | 01:52 PM
subford's Avatar
subford
Possible causes:
-- Open or short in harnesses (internal/external).
-- Solenoid damaged electrically.
Key off.
Disconnect transmission vehicle harness connector.
Key on, engine off.
Measure the voltage between VPWR, EPC PWR circuit at transmission vehicle harness connector and chassis/battery ground.
Is voltage greater than 10.5 volts?
Old Apr 30, 2006 | 10:40 PM
Fully_Loaded
What is the VPWR and EPC PWR circuit? So the test is at the tranny harness plug. The chassis/battery ground is a seperate test where I disconnect the negative and test from the negative terminal to the negative cable correct? I am not very good with the electrical end of testing. I appreciate the response.
Old May 2, 2006 | 08:46 AM
subford's Avatar
subford
I am sorry that I gave you the wrong information, the information I gave you was for a Code 998 KOEO.
VPWR: Vehicle Power.
EPC: Electronic Pressure Control.
A 998 KOER says:
Key On Engine Running:
Refer to these EEC-IV DTC Charts for direction to diagnose the Continuous DTC received during Key On Engine Off Self-Test.
And I can not seam to find the next step on:
I would check the Fuse or Fuse Link to your Keep Alive Power (Pin 1) of the EEC (PCM).
Old May 2, 2006 | 09:27 PM
Fully_Loaded
I will check it out thanks
