Sponsored by: Real Truck
Traction Bars
Old Apr 30, 2006 | 01:06 PM
marv02's Avatar
marv02
Traction Bars
I been looking for a set of traction Bars for my F250 4X4 can any one help me in finding a set.
Just about every set I have looked at so far they cost way to much I am cheep I cant see $300 to $800 for a set they not much to them I dont want to be robbed
Any one can make me a set.
Old May 1, 2006 | 09:01 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Unless you find a set of used ones, I think you're out of luck.
With all the welding and fabrication involved in "making a set", unless you're doing the work yourself, $300-$500 isn't all that far off the mark to have a set made for you.
If it were me, and I was looking for a cheap way to get more stability for the rear diff, I might find a set of heavier-duty leaf springs which will keep the axle wrap down (or just strap the front of the big flat bottom leaf to the rest of the leaves - which might involve some driveline angle adjustments).
Old May 1, 2006 | 11:38 PM
marv02's Avatar
marv02
Forking out the cash
I broke down and having a set of ladder / traction bars fabricated from the local off road racing shop I seen some his work good stuff he charging me $435.00 more than I wanted to spend but once again you get what you pay for.
The ownner is a racer and he saids most of the ladder / traction bar you by that bolt on look great but don't work the best.
And what he telling me if you remove the rear shackles and lube up the pivet bolt point real good double nut the during installating and dont torque the down super tight to the bushing you can get a better ride out of thr truck this will let the shacle move.
We also talked aboiut removing one of the leaf spring to get a better ride and installing a air bag and adjust the ride when you haul some weight.
Old May 3, 2006 | 02:10 AM
schmidt64's Avatar
schmidt64
JC whitney makes a bolt on traction bar for the 99-06 SD 4x4 for $79.95
