steering problem f150 1991
Old Apr 30, 2006 | 09:29 AM
cbjr61's Avatar
cbjr61
Question steering problem f150 1991
problem with my steering not sure if its the tires or something else
driving along straight and all of a sudden it will jerk left hard have to pull it back quickly doesn t matter what speed im travelling . then its fine just does it occosinally. don t know what to do
the truck is a 1991 f150 4x4
what do i check and how
Old May 15, 2006 | 08:06 AM
cbjr61's Avatar
cbjr61
still having problem i was hoping someone would have an idea of what i should check and how to do it
thanks
Old May 15, 2006 | 05:27 PM
Twitche's Avatar
Twitche
I have no idea what it is but it sounds a little like bump-steer. This is caused by several things from a bad shock to bad tie rod ends or ball joints. To check these jack up the front end and try to wiggle each tire. If it wiggles up and down, its probably the ball joints. If it wiggles left to right, it is probably the tie rod ends.
Old May 15, 2006 | 05:54 PM
andym's Avatar
andym
Yeah, I would say something is pretty loose in the front end. Check all the bushings, ball joints, tie rod ends, etc.
Old May 15, 2006 | 11:14 PM
raleigho's Avatar
raleigho
check radius arm bushings and axle pivot bushings. The Radius Arm bushings cause a pulling condition for sure.
Old May 16, 2006 | 01:25 AM
monarokid's Avatar
monarokid
Had a similar problem with 89 F 150. Turned out it was a worn collapsible steering column. Get someone to gently wiggle any play in steering wheel while you have a look at column to see if it's that. Was causing bump steer even at low speeds.
monarokid
