Ring gear size question
Old Apr 29, 2006 | 06:02 PM
farmer2's Avatar
farmer2
I have a 2000 4 cyl ranger with 5 speed trans and the axle code is 86. The only thing I can find about that is that it is a 3.73 non LS.
Is there a way to find out what the ring gear size is so I can order a shim pack for the pinion and carrier and set the whine I have in it.
Even better does anyone have the I.D. and O.D. of the pinion and carrier shims?
Thanks, Dave
Oh yeah, I just bought this truck and am new to the site here. Looks like a nice place to get info from.
Old Apr 29, 2006 | 07:02 PM
farmer2's Avatar
farmer2
I found the ring gear size on the rear dif tag. It has a 7.5. I still need the I.D.s and O.D.s of the pinion and carrier if someone could help there.
Dave
Old Apr 30, 2006 | 06:29 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 1, 2006 | 05:10 PM
farmer2's Avatar
farmer2
Thanks for the welcome!
Does anybody know what parts are the same from the 7.5's to the 8.8's?
Not to many rear end guys in here I see
Old May 2, 2006 | 12:21 AM
Waves's Avatar
Waves
I've had a couple upgraded and re-geard, but have always had that type of work done. I don't think the two diffs are interchangable (but I am not an expert and could very well be wrong), I am pretty sure the components of the 8.8...like the axel shafts are larger and I know that the difrent drive systems for them, such as a locker or a track-lock system are difrent for the two difrent axel sizes, or I should say when you order them they do ask for specific sizes and some parts for an 8.8 are not available for a 7.5 so I assume they are a difrent size or of some difrence in construction as well. I'm sorry I don't know any of the exact part numbers or have any more info or input beyond that.
Old May 2, 2006 | 05:04 PM
farmer2's Avatar
farmer2
Appreciate the info. I have been doing some info on ordering what it takes to re-shim the pinion/carrier. It looked like the pinion spacer and shims could be the same. It even looks like the pinion and carrier shims are the same for the GM 7.5 10 bolt also, according to the summit racing catalog.
I just bought this ranger and never worked on a ford rear yet but have done at least 20 gear changes to the GM rears.
This rangers rear is very noisy on the backlash part and needs to be set right.
Thanks again
Dave
Old May 3, 2006 | 08:00 PM
Bart99GT's Avatar
Bart99GT
The shim kit for the 7.5" and 8.8" are one in the same. They use the same bearings, races, axles, etc..
The ONLY case I know of where the 8.8" rear uses a different axle is with some of the Explorers that have the 31 spline axles. Everything else that has either a 7.5" or 8.8" rear end in the Ford lineup uses 28 spline axles, wether it be a Ranger, Mustang, Crown Vic, etc..
Old May 5, 2006 | 06:37 PM
farmer2's Avatar
farmer2
Just a update on the noise and shims.
The rear was serviced at a dealer before me buying it and they replaced the bearings in the rear is all I was told. Not to bash anyone, but they had the carrier shims reversed giving me .040 backlash. After inspecting and reinstalling, the backlask fell on .007 and the tooth pattern was perfect.
I have done quite a few 7.5 10 bolt GM's, so I had shims laying around. The carriers use the same size shims for both for FYI later down the road. The pinion was good at 15 in lbs of preload turning, so I didnt touch it. I cant answer for the size being the same for GM then.
11F250XL
Jun 9, 2016 11:04 AM
axelgawn
Georgia Chapter
Mar 5, 2016 06:20 AM
PJ-Hunter
Oct 30, 2015 10:02 AM
Ron94150
Aug 28, 2015 09:35 PM
rs4-380
Feb 6, 2015 05:52 AM
